Author Topic: exFAT filesystem support as of 10.6.5 (Nov 2010)  (Read 10417 times)
« on: May 23, 2015, 08:42:00 PM »
https://discussions.apple.com/thread/4745362?start=0&tstart=0
exFAT!
works on Windows (XP, Vista, 7 and 8)
and OS X (10.6.5 and newer), so it should work without any problem.
If you format exfat on OS X, a Windows PC should be able to write on it without any problem.
https://www.macrumors.com/2010/11/10/apple-releases-mac-os-x-10-6-5/
http://arstechnica.com/information-technology/2013/06/review-is-microsofts-new-data-sharing-system-a-cross-platform-savior/
« Last Edit: December 11, 2023, 03:32:28 AM by chrisNova777 »
when was exFAT first released?
« Reply #1 on: January 15, 2023, 01:33:58 PM »
exFat was introduced on Windows Vista with the release of Windows Vista's (Sp1) (January 30, 2007)
and then a bit later on it was releasd also for XP(sp2,sp3) via an update.  Windows XP requires update KB955704 (Jan 2009) to be installed to support exFAT. the original download page can be viewed at this link which says that its intended for use with XP service pack 2, or XP sp3.. (not sure if it will work with vanilla XP... anyone know? please post) http://web.archive.org/web/20090201042823/http://www.microsoft.com/downloads/details.aspx?FamilyID=1cbe3906-ddd1-4ca2-b727-c2dff5e30f61&displaylang=en
https://en.wikipedia.org/wiki/ExFAT
exFAT was introduced in late 2006 as part of Windows CE 6.0 (Nov 2006), an embedded Windows operating system. Most of the vendors signing on for licenses are manufacturers of embedded systems or device manufacturers that produce media formatted with exFAT. The entire File Allocation Table (FAT) family, exFAT included, is used for embedded systems because it is lightweight and is better suited for solutions that have low memory and low power requirements, and can be easily implemented in firmware.
also of course, exFAT has both Mac + PC support, and support for files larger than 4GB
Unlike the NTFS file system which is read-only on Mac (NTFS for Mac can help with that), macOS fully supports reading and writing exFAT external drives starting from Mac OS X10.6.5 in 2009. (Snow Leopard and up)
« Last Edit: January 15, 2023, 01:55:28 PM by chrisNova777 »
