Author Topic: use reason 6.5 in demo mode FREE on Windows XP  (Read 5287 times)
« on: August 31, 2015, 05:56:22 AM »
the last version of reason to work on windows XP is v6.5
u can download that version here:
https://www.propellerheads.se/download/index.cfm?fuseaction=get_article&article=reason653
can also download the soundbanks here:
https://www.propellerheads.se/download/reason/soundbanks
once installed, u can set up reason to respond to incoming midi
for example i installed MIDIOX midi yoke, and was able to trigger
reasons sounds, from cubase.. note that i wasn't using REWIRE because
i used an ancient version of cubase that didn't even support audio
let alone rewire… and routed the midi into reason via midi yoke
if u have more than one sound card, you can set up one audio device to
respond to reason, and then physically wire the audio outputs from reason 6.5
into your other audio device using it with whichever other app you are using
and record the audio!!!
or u could do the same thing with two computers + use reason with a 2nd
computer for free in demo mode!
Re: use reason 6.5 in demo mode FREE on Windows XP
« Reply #1 on: October 29, 2018, 11:46:55 AM »
v6.5 of reason requires Service Pack 3 on windows xp or it wont even install  ;D
« Reply #2 on: December 06, 2019, 03:48:08 PM »
https://www.gear4music.com/us/en/Recording-and-Computers/Propellerhead-Reason-65-Upgrade-Free-Upgrade-to-Reason-7/JKQ
https://www.americanmusical.com/propellerhead-reason-65-music-production-software/p/LIN-REASON65-LIST
https://www.reasonstudios.com/download/index.cfm?fuseaction=get_article&article=reason651
https://www.reasonstudios.com/download/index.cfm?fuseaction=get_article&article=reason652
https://www.reasonstudios.com/download/index.cfm?fuseaction=get_article&article=reason653
http://cdn.propellerheads.se/Reason6/Reason_6_Soundbanks.zip
Reason 6.5 System Requirements:
Mac OS X
Intel Mac (multiple cores highly recommended)
1 GB RAM or more
Mac OS X 10.5.8 or later
3 GB free hard disk space (program may use up to 20 GB scratch disk space)
Monitor with 1024x768 resolution or larger
A MIDI interface and a MIDI keyboard recommended
Internet connection for registration
Free USB port for Ignition Key
CoreAudio compliant audio interface or built-in audio hardware
Windows:
Intel Pentium 4 / AMD Opteron or better (multiple cores highly recommended)
1GB RAM
Windows XP SP3, Vista or Windows 7 (Vista or Windows 7 required for 64-bit)
A 16 bit Windows compatible audio card, preferably with an ASIO driver
Free USB port for Ignition Key A MIDI interface and a MIDI keyboard recommended
