Author Topic: 19" Roland SDX-330 (1994) dimensional xpander  (Read 7357 times)
« on: December 02, 2015, 07:48:45 PM »
Roland SDX-330
http://www.vintagedigital.com.au/roland-sdx-330-dimensional-expander/
http://www.soundonsound.com/sos/1994_articles/jul94/rolandsdx330.html
http://www.polynominal.com/roland-sdx330/
http://cdn.roland.com/assets/media/pdf/SDX-330_OM.pdf
STEREO CHORUS
a single LFO (triangle or sinusoidal) with variable phase and orientation between left and right channel can be selected.
CPU NEC upd70433.  STEREO 3D CHORUS
same as previous with some extra 3D RSS controls like azimuth height orientation (speakers must be placed in specific positioning)
CPU NEC upd70433.  3D PANNER
the sounds moves around the listener, also based on RSS
CPU NEC upd70433.  SPACE CHORUS
an emulation of the vintage classic SDD320 dimension D
CPU NEC upd70433.  2-BANDS CHORUS
composed by low band (LFO1 tri sin) + hi-band (LFO2 tri sin). Each modulator has individual rate and depth on the frequencies that can be split between 400Hz-4kHz (crossover frequency)
CPU NEC upd70433.  3-BANDS CHORUS
created by low band (LFO1 tri sin) + middle Band (LFO2 tri sin) hi-band (LFO3 tri sin) also here modulators are independent.
Two Crossover points frequencies: 100Hz-1kHz and 800Hz-8kHz
CPU NEC upd70433.  4-BANDS CHORUS
4 bands, 4 LFO: Low+lowmiddle+highmiddle+hi bands. Obviously 3 crossover points frequencies at 100Hz-1kHz, 400Hz-4kHz and 800Hz-8kHz
CPU NEC upd70433.  STEREO 8 PHASE CHORUS
8 independent LFO (frequency/phase/depth) modulators with 2 possible waveforms: sine and triangle.
CPU NEC upd70433.  16-PHASES CHORUS
no less than 16 LFO, however these cannot be controlled one by one, but macro-edited using 6 different presets chaining modes
CPU NEC upd70433.  DETUNE CHORUS
based on 6 real-time pitch-shifter engines and each shifter can be set at pitch/panning/level parameters
CPU NEC upd70433.  ENSEMBLE
based on 2 independent LFO for each input + EQ, 6 different mode presets.
CPU NEC upd70433.  WAVE CHORUS
6 LFO at same time with advanced waveforms: Sin/Tri/Exp/ocw1/ocw2/ocw3
CPU NEC upd70433.  VINTAGE CHORUS
emulation of classic analogue chorus model
CPU NEC upd70433.  STEREO FLANGER
emulation of standard flanger effect composed by a single LFO with depth, frequency and 5 different waveforms (tri/sin/exp/ofw1/ofw2)
CPU NEC upd70433.  ROTARY
emulation of Leslie and doppler effect including rotor+horn speed, brake and frequency speed
CPU NEC upd70433.  AMBIENCE CHORUS
a special ambient chorus based on modulators followed by a special lowpass Filter (or highpass mode) + a final stage EQ.
