Author Topic: Roland JV2080 Samples Via Legowelt!  (Read 4058 times)
« on: August 03, 2016, 12:08:55 PM »
http://www.legowelt.org/Legowelt-Elektrovolt-RolandJV2080sampleKit.zip
Bored of your mundaine analog bleeps ??? Looking for some fresh inspiration?????
Check out the Legowelt Elektrovolt Roland JV2080 sample kit!
Load it up in your Ableton simpler,Reason, MPC, Octatrack, Octamed,
Electribes, Trackers, Fruityloops, S900, SP1200, Emulator, EPS1, ASR-10 whatever u use
322 samples from the legendary 1997 Roland JV2080 MONSTER synthesizer
All free to use in your sampler!!!
This time Legowelt's protege and studio assistant intern engineer prof.Dr.Dr.Elektrovolt joins the
party and uses his sophisticated deep synth programming skills to squeeze out
the absolute freakyness of this machine.
Atmospheres, pads, strings, thick juicy basses, mesmerizing synth tones, tantalizing
sequences, Ethno Synthesis + much more
The Roland JV2080 is a digital rack synth from 1997 that used
wave rom sounds into a fathomless semi modular synthesis engine.
Are you ready for the Haunted Seacucumber, Zandwezen, Basket Wieners and
whatever adventures await you with these samples???
203.9 MB Zip File containing 322 16 bit 44kHZ wav samples
including hi - res pix and info pdf
