Author Topic: steinberg midex 3 (2003?)  (Read 18800 times)
Re: steinberg midex 3 (2003?)
« Reply #1 on: March 06, 2017, 05:05:48 AM »
ftp://ftp.steinberg.net/Archives/Hardware/Midex_3/Pc/Midex_3_1903/readme.pdf
readme + manual claim compatibility with win98 aswell as win98se + winme
« Reply #2 on: July 05, 2017, 09:34:33 AM »
New unsupported Midex 3/8 drivers available
https://www.steinberg.net/forums/viewtopic.php?f=150&t=11690
These drivers support Windows Vista and Windows 7 as well as Mac OS X 10.5, 10.6 and 10.7.
But again, they are completely unsupported! If you want to use them, it is at your own risk! Only modifications to fit these drivers to the new operating systems have been made. There are no additional bugfixes included!
Nevertheless, we hope that some of you can start using their Midex devices again on current operating systems.
ftp://ftp.steinberg.net/Archives/Hardware/Midex_3/Midex3OperationManual.pdf
Offline foksadure
  • Stuck in 1997
« Reply #3 on: December 25, 2022, 07:17:15 PM »
Just got a couple of these oddly designed boxes.
Lack of screws means it's not as easy to tear down as the Midex-8. Still investigating. No boilerplate either.
Yet it's working like a charm with the unsupported Midex_3_1964 drivers on Win10 x64 (21H2), using Cubase 5 as LTB compatible sequencer.
The unit has a relay that switches automatically between MIDI Thru to MIDI computer mode when drivers are activated by a MIDI software.
Neat!
« Last Edit: December 26, 2022, 04:41:20 AM by foksadure »
Offline smilesdavis
« Reply #4 on: December 26, 2022, 10:42:37 AM »
a couple? neat
i just got one in orginal packing :D
Offline smilesdavis
« Reply #5 on: December 31, 2022, 06:22:14 AM »
ok so the Mac OS 9 driver wasnt preserved on wayback history
anyone got the mac os 9 driver, please share
Offline foksadure
  • Stuck in 1997
« Reply #6 on: December 31, 2022, 12:20:29 PM »
One can't get enough Steinberg's LTB USB MIDI interfaces. :P
Like the Midex-8, the Midex-3 is an EZ-USB design, with a Cypress_AN2131SC as the main USB/MCU component here.
No need for an extra UART to run only 1x3 I/O.
Similar design than the Midiman/M-Audio Midisport 2x2: https://youtu.be/qOnSU3csuE4
Except for the firmware of course, which handle LTB when used with a compatible software sequencer.
To bad they didn't come up with a LED when LTB is activated. Emagic did not either with AMT.
The housing is just two Macrolon shells plugged together with a tad of glue, holding the electronic board tightly.
This one has a BEK factory sticker which numbers have nothing to do with the one on the registration card.
Nothing on the cardboard either, but Made in Germany.
Most likely built by BEK Systemtechnik, which happen to build products for Kemper Digital GmbH, Access Music mother company (and LTB developper):
https://www.bek-systemtechnik.de/en/products/references/
The included DRIVERS_2_2002 CD-Rom is hybrid PC/MAC, but I only could get access to the PC files (about 224MB of various boring Steinberg stuff) .
Made a RAW image with CloneCD: it weights 474MB zipped, so there's definitely extra stuff included.
You can grab it there.
« Last Edit: January 01, 2023, 04:43:44 PM by foksadure »
Offline smilesdavis
« Reply #7 on: January 01, 2023, 01:02:29 PM »
i just realized my USB-2-MIDI is a repackaged M-audio MIDISport 2x2, not a MIDEX-3
dayum
Offline foksadure
  • Stuck in 1997
« Reply #8 on: January 01, 2023, 02:31:16 PM »
Tough luck. :-\
You still can point people from macos9lives to this thread and in the meantime try to read the drivers CD-ROM image to check if the OS9 version is there.
There's no point for me to create an user account at macos9lives to post this:
http://macos9lives.com/smforum/index.php?topic=3432.0
Offline smilesdavis
« Reply #9 on: January 01, 2023, 02:37:38 PM »
thanks for all your awsome work. i found the driver in the meantime. there was a cd in the rear of the box.
i think i need a midex-3 now.
Offline foksadure
  • Stuck in 1997
« Reply #10 on: January 01, 2023, 05:04:49 PM »
Is it the same CD called DRIVER_2_2022 that I posted a link to the copy of?
You could do the other way around and use the Midisport 2x2 on OS9.
https://www.macintoshrepository.org/23093-os9-midisport-drivers
Someone wrote the units were the same design (almost!) and M-Audio Windows drivers were compatible with the Midex-3. :P
https://forums.steinberg.net/t/ltb-und-midex3-bzw-midex8-fur-den-mulleimer/615644
LTB just does make sense on older systems using Cubase VST, SX or Cubase 6.
In all seriousness, you'd better get a Midex-8: not much more expensive and easier to catch on eBay.
8x8 I/O are way more useful with an extensive DIN MIDI rig, 1990s style.
« Last Edit: January 01, 2023, 05:20:27 PM by foksadure »
Offline smilesdavis
« Reply #11 on: January 01, 2023, 09:51:21 PM »
1999
Offline foksadure
  • Stuck in 1997
« Reply #12 on: January 02, 2023, 02:08:01 PM »
So that's a 1999 USB-2-MIDI Steinberg interface, which was a rebadged Midiman/M-Audio Midisport 2x2 as they admitted themselves:
https://helpcenter.steinberg.de/hc/en-us/articles/206904330-Drivers-for-the-USB-2-MIDI-interface
The 2002 Midex-3 look alike housing explains why people are mixing it up with the later, which is not the same I/O design (2x2 vs 1X3) and does not use the same drivers (because of LTB).
Cool findings, that's a rarity!
Offline smilesdavis
« Reply #13 on: January 07, 2023, 05:44:50 AM »
i know OVP thats why i got it
