Author Topic: turtle beach tropez (1996)  (Read 9964 times)
Online chrisNova777
« on: November 14, 2016, 06:39:48 PM »
http://web.archive.org/web/19970125151306/http://www.etcetera.co.uk/et03007.htm
urtle Beach Tropez Plus
The Tropez Plus is
a sound card,
a synthesiser
and a Digital MIDI sampler
all in one.
The best just got better ... award-winning Tropez technology, the PC Magazine Editors'
Choice for best multimedia sound card, makes room for Tropez Plus, the next generation
of audio dynamite.
With Windows '95 Plug and Play compatibility, installation has never been so easy. And our
SampleStore technology not only give you the best 32-voice Wavetable synthesizer on
the market today, but by adding your own RAM (up to 12MB), you can add any WAVE audio
file for a limitless palette of sound.
Then bring your music tracks alive using effects in the MIDI synthesizer ... like delay,
reverb, EQ, flange, chorus, and more. All that, plus the enhanced IDE interface, which
enables you to take advantage of the latest multimedia titles by controlling the newest CD-ROM
drives.
Compatibility
Windows 95 Plug and Play compatible
SoundBlaster compatible
MPU-401 compatible MIDI interface
Key Features
Stereo 16-bit recording and playback
Game compatibility, MPU-401 interface (DOS and Windows)
ICS WaveFront wavetable synthesizer with a 4MB ROM set
Yamaha OPL3 FM synthesizer
Yamaha DSP effects processor
Up to 48KHz sampling rate
SampleStore allows you to take any .WAV file and use it as a MIDI instrument (expandable up to 12MB using standard SIMMs)
Enhanced IDE (EIDE) ATAPI controller on-board
Simultaneous record & playback (PC dependant: requires 2DMA's from 0,1,3 and Pentium PC)
Tropez Plus Specifications
Audio Performance
Signal to Noise: -89dB (A weighted) -87dB (Unweighted)
Total Harmonic Distortion: < 0.01% (A Weighted) < 0.02% (Unweighted)
Phase Response: +/- 0.1 degrees
Stereo Crosstalk: 100Hz -90dBV, 1kHz -89dBV, 10kHz -83dBV
IM Distortion: < 0.01%
Frequency Response: 20Hz-22KHz, +0/-1dB
Sample Rates: Selectable between 4kHz and 48kHz
Resolution: 16-bit and 8-bit
Audio Channels: Stereo or Mono
A/D Converter: 64X oversampled sigma-delta, 16-bit
D/A Converter: 8X interpolating filter 64X oversampled, 16-bit DMA mode for increased performance
Simultaneous Play and Record Capability
Supported Interfaces
MIDI Interface: Up to 2 MPU-401 compatible external interfaces using optional cables
CD-ROM Interface: Enhanced IDE Controller (ATAPI)
Joystick Port
Inputs: Line level, Aux & Mic level
Outputs: stereo line level
Wavetable Synthesizer
General MIDI compatible: Yes
Audio effects like Delay, EQ, and Reverb using Yamaha DSP
128 Instruments in 4MB Wavetable ROM set
32 Simultaneous Voices
Sample Data Formats: 16-bit, 8-bit, and 8-bit u-law
SampleStore(tm)
RAM Size: Upgradable to 12 megabytes using standard SIMMs
FM Synthesizer
Stereo FM Synthesizer (Yamaha OPL3)
Adlib Compatible
20 independent stereo voices of FM synthesized sounds
4 FM operators per voice
Windows Software
WavePatch(tm): Patch editor for wavetable synthesizer
Wave SE(tm): WAV audio and sample editing program with Loop Editor
MicroWave(tm): OLE compatible .WAV recorder/editor for business applications
Stratos(tm): MIDI song writing software
Sierra Audio Rack: Featuring stealth mode
MousePlayer: MIDI controller
System Requirements
PC with Windows 3.1x or Windows 95
Powered speakers or headphones
