Author Topic: using a flash drive with an ipad (Article, 2014)  (Read 6101 times)
« on: January 06, 2017, 02:19:43 AM »
http://www.macworld.com/article/2103582/using-a-flash-drive-with-an-ipad.html
In a very limited way, yes. It’s like this.
You can attach some flash drives to Apple’s $29 iPad Camera Connection Kit. (If you have an iPad with a Lightning connector you’ll additionally need Apple’s $29 Lightning to USB Camera Adapter.) Let me underscore some. Some flash drives require more power than the iPad can provide and won’t work. For example, I had luck with a low-capacity (64MB) flash drive but a 4GB drive was deemed incompatible by the iPad.
The flash drive must be formatted as a FAT volume. These drives are formatted this way by default, but to be sure, plug the flash drive into your Mac, launch Disk Utility (found in /Applications/Utilities), select the drive, click the Erase tab, choose MS-DOS (FAT) from the Format pop-up menu, and click the Erase button. In the sheet that appears confirm that you want to erase the drive by clicking Erase.
