Author Topic: M-audio Delta 1010AI (2000) adds ADAT capability to 1010 (not compatible 1010LT)  (Read 13189 times)
in conjunction with the 1010’s PCI host card, it functions as an ADAT I/O interface for PC or Mac that operates at up to 24 bit 48kHz.
https://web.archive.org/web/20000824133006fw_/http://www.midiman.net:80/m-audio/html/products/delt101ai.htm
http://web.archive.org/web/20001110045100/http://www.midiman.net/m-audio/html/products/delt101ai.htm
http://www.m-audio.ca/images/global/manuals/Delta1010AI_Manual.pdf
http://www.digitalprosound.com/Htm/Articles/May/MA-DeltaAI.htm
M Audio Announces the Delta 1010 ADAT Interface Shipping in May 2000
Search Digital Pro Sound
Click here to search all Digital Media Net
The Delta 1010 ADAT Interface, companion to the Delta 1010 Recording System (click image for larger view)
Arcadia, Calif., May 22, 2000 -- In response to the demand for an ADAT-compatible Delta 1010, M Audio offers the Delta 1010-AI. The 1010-AI is a companion piece for the Delta 1010 which allows ADAT users access to the audio quality that made the Delta 1010 an instant success. The 1010-AI offers several modes of operation. First, in conjunction with the 1010’s PCI host card, it functions as an ADAT I/O interface for PC or Mac that operates at up to 24 bit 48kHz. Equally as impressive is the fact that the 1010-AI may be configured as a powerful front-end and monitoring system for ADATs -- the Delta 1010’s converters may be used to record and/or playback from your ADAT instead of using the stock ADAT converters. The Delta 1010-AI even supports 4 mixed modes which are combinations of signal routing between the PCI host card, 1010 external converter box, and an external ADAT. Features include:
• ADAT* I/O for PC, Mac, and NT operating up to a full 24 bit 48kHz.
• Record through and playback using premium 24 bit converters.
• Simultaneous ADAT recording and computer playback.
• Select between analog and ADAT optical for computer input.
• Select between computer out and ADAT in for routing to the D/A section.
• Select between computer out and analog in for ADAT input source.
• ADAT In to ADAT Out “Bypass” mode.
* ADAT is a registered trademark of Alesis.
Minimum System Requirements:
• Windows 95, 98 or NT • Pentium II 300MHz - (96kHz operation) Pentium 300 MMX - (48kHz or less)
• 128 MB of PC100 RAM - (96kHz operation) 64 MB of SDRAM - (48kHz or less)
• UDMA EIDE or SCSI HDD Macintosh: G4, G3 or G3 accelerator
Source: Midiman/M Audio, Inc.
Web: www.maudio.com
http://www.nodevice.com/user_manual/m-audio/audio/delta-1010-ai.html
In response to the demand for an ADAT-compatible Delta 1010, M Audio offers the Delta 1010-AI. The 1010-AI is a companion piece for the Delta 1010 which allows ADAT users access to the power, punch, and pristine audio quality that made the Delta 1010 an instant legend. The 1010-AI offers several modes of operation. First, in conjunction with the 1010’s PCI host card, it functions as an ADAT I/O interface for PC or Mac that operates at up to 24 bit 48kHz. Equally as impressive is the fact that the 1010-AI may be configured as a powerful front-end and monitoring system for ADATs -- the Delta 1010’s famous converters may be used to record and/or playback from your ADAT instead of using the stock ADAT converters. The Delta 1010-AI even supports 4 mixed modes which are combinations of signal routing between the PCI host card, 1010 external converter box, and an external ADAT.
Add the 1010AI to the Delta 1010 for a powerhouse 24bit 96 kHz system that
includes: 8-in 8-out analog, S/PDIF I/O, Litepipe I/O, digital mixing and
routing, and legendary converters and drivers.
Features
Minimum System Requirements for Mac:
System 8.5.1 or above
128 MB RAM for 96kHz operation
96 MB RAM for 48kHz operation
