Author Topic: CAKEWALK DOS 5.0 "LIVE" search (Aug 1994, software)  (Read 26757 times)
ElgickX
« on: April 13, 2017, 02:04:40 PM »
  8)  Hello all,   I'm in search of the installer software for CAKEWALK DOS 5.0 "LIVE".  See photo of it installed on a friend's laptop taken yesterday.  It is here installed on an old IBM Thinkpad running Windows 98 SE.  Would appreciate your help in finding the installer for CAKEWALK DOS 5.0 "LIVE".   Thanks in advance.
Regards
« Last Edit: June 26, 2017, 08:15:59 PM by chrisNova777 »
Re: CAKEWALK DOS 5.0 "LIVE" search
« Reply #1 on: April 13, 2017, 06:10:12 PM »
so wait - your friend has an installed copy but has lost his install disk for the application?
if so you might try contacting cakewalk they are still in business? long shot but might work?
so basically this app turns a number of midi files into a complete segment for live playback performance?
was it packaged with the original cakewalk 5.0 for DOS? or a completely seperately purchased product?
ElgickX
« Reply #2 on: April 14, 2017, 12:42:00 AM »
Yes, the install disk is lost and it appears to be a separate install. Here's a photo of the PC's desktop, will also ask him to check Cakewalk about it.
Regards
« Reply #3 on: April 14, 2017, 10:16:26 PM »
is there any chance that it came bundled with Cakewalk Pro Audio 9??
actualy that doesnt make sense given the date on the screen (1987-1990?)
ElgickX
« Reply #4 on: April 18, 2017, 07:00:58 PM »
It's a no go from Cakewalk Support so I'll have fish somewhere yonder.
« Reply #5 on: April 21, 2017, 11:12:02 PM »
yea they probably are as dumbfounded + clueless as i am.
im glad u attached the photo of it though.. as it will get some people interested enough to track it down perhaps??
i guess we are out of luck unless u speak to Hendershott himself!
ElgickX
« Reply #6 on: April 23, 2017, 01:19:39 AM »
Getting a contact number for him would be great, maybe someone will throw in that info.
After downloading * CW5PRO.zip (591.55 kB )  and unzipping it, how do l prepare it for installation in Windows 98 SE correctly ?  I gave it a try, got as far as it showing that the installation was completed, but it was no where to be found after that.  Need all the help l can get, thanks much.
Regards
ElgickX
« Reply #7 on: April 24, 2017, 12:06:42 AM »
Well it seems l couldn't see for look'n........ Cakewalk LIVE ! 5.0 DOS was right there all the time.
« Reply #8 on: April 24, 2017, 10:34:12 AM »
so..
am i right in assuming from your limited response that the LIVE! utility is an extra command line application that is part of the Cakewalk 5.0 for DOS install package
correct?
ElgickX
« Reply #9 on: April 24, 2017, 03:50:14 PM »
You are correct, it is within Cakewalk DOS 5.0 ..... after finally getting Cakewalk DOS 5.0 installed I clicked on
Start > Find....typed in Cakewalk Live, which took me to where a bunch of Cakewalk stuff was....I then scrolled down until l found Cakewalk Live...double clicked on it....it opened stating l would need an interface but
l chose to continue without it.  Afterward l dragged the Cakewalk Live icon to desktop, which created a shortcut.
  I'm almost sure there's a better way to get this happening, but l'll leave that to you Pros.
Regards
« Reply #10 on: April 26, 2017, 04:42:00 PM »
thanks for recanting + sharing your experience Elgicx
all the best to you + your explorations ;)
ElgickX
« Reply #11 on: May 09, 2017, 06:03:16 PM »
Hi,
Is there anyone with the DOS or Windows 98se Driver for the Music Quest 2Port/SE Interface, if you do, could you also post the install instructions, step by step please.  Thanks.
Regards
« Reply #12 on: June 26, 2017, 07:54:30 PM »
there probably was never a windows 98se driver made for it..
http://web.archive.org/web/19961113031203/http://www.opcode.com:80/downloads/pc_hardware/
the driver can be downloaded from this location
download the .exe file
further product info:
http://web.archive.org/web/19961113040944/http://www.opcode.com:80/products/winhardware/2portse.html
my page here on oldschooldaw:
http://www.oldschooldaw.com/forums/index.php?topic=537
Re: CAKEWALK DOS 5.0 "LIVE" search (Aug 1994, software)
« Reply #13 on: June 26, 2017, 08:17:10 PM »
http://www.latinrank.com/buscadriver/placasdesonido/77309.htm
ok im wrong there was a 2portSE driver for win98
but actually the files listed are dated before win98 back in 1995 so its not a new driver at all
  Length     Date   Time    Name
      186  07-27-95 19:09   origdrv/OEMSETUP.INF
    15337  09-30-94 03:00   origdrv/2PSEDIAG.HLP
   203834  09-30-94 03:00   origdrv/2PSEDIAG.EXE
        8  07-31-95 10:10   origdrv/2PSEDIAG.DAT
    20560  08-04-95 17:38   origdrv/MQ2PRTSE.DRV
    23424  02-02-96 11:37   origdrv/README.WRI
        0  07-31-02 09:28   origdrv/
   263349                   7 files
ElgickX
« Reply #14 on: July 31, 2017, 02:00:07 PM »
Thanks very much, the driver install guide worked out great !!
Regards
