Author Topic: Echo Gina 3G (Aug 2004)  (Read 10267 times)
« on: October 12, 2014, 06:08:04 AM »
http://web.archive.org/web/20040810194241/http://www.echoaudio.com/Products/PCI/Gina3G/index.php
Gina3G is perfect for the budget-minded musician who wants to get into digital recording without sacrificing quality for price. You won't need a mixer or studio monitors to get started here. Gina3G has all you need: 2 universal inputs with mic preamps, 6 balanced analog outputs, and a headphone output. ADAT lightpipe, optical and coaxial S/PDIF, and MIDI are included as well; so as your studio grows, Gina3G will be able to work with all your new gear. It comes with a 8' cable and PCI card that connects to the audio interface. Gina3G is compatible with PCI-X (3.3 or 5 volt) motherboards and Power Mac G5 computers, as well as older systems.
Hardware Features
2 auto-sensing universal inputs (mic/guitar/line):
        110dB (A-weighted) dynamic range
        Meters, trim knobs, & phantom power
    6 balanced ¼" analog outputs:
        114dB (A-weighted) dynamic range
        +4dBu / -10dBV nominal levels
    S/PDIF I/O (coax & optical) at 24-bit/96kHz
    ADAT optical digital I/O
    MIDI I/O
    Stereo headphone output with volume knob
    Sync via S/PDIF, ADAT, or MTC
    Supports full duplex 10 channel in, 14 channel out operation
    Heavy-duty aluminum case
    8' cable to connect to PC
    PCI bus mastering interface:
        Bus powered
        Works with PCI-X (3.3/5 volt) & Power Mac G5
    A/D & D/A converters in external breakout box
    56-bit / 100mHz DSP for digital mixing
        Near zero latency hardware monitoring
Software Features
    Software console for monitoring, metering, and setting levels
    Low-latency drivers support all major pro audio software:
        Low Latency ASIO 2.0
        GSIF 2.0 (Gigastudio 3 w/ low latency MIDI)
        WDM kernel streaming mode
        CoreAudio & CoreMIDI
    Surround sound support:
        5.1 & 7.1 output w/ delay management
        AC3, DTS, & WMA9 output over S/PDIF
    SuperChannel™ resource sharing:
        Split I/O between multiple applications
    PureWave™ mode for bit accurate digital I/O
System Requirements
    PC System requirements:
        Windows ME/2000/XP
        Genuine Intel Pentium or AMD Athlon CPU
        Motherboard with Intel, AMD, Via, or NVIDIA chipset
        256 MB RAM (512 MB recommended)
    Mac System Requirements
        Mac OS X (10.2 or later)
        G4 or better processor (Power Mac G5 compatible)
« Last Edit: October 13, 2014, 11:42:03 AM by chrisNova777 »
