Author Topic: M-Audio Delta DiO 2496 (1999) supports win95  (Read 13270 times)
« on: October 13, 2014, 09:54:41 AM »
https://web.archive.org/web/20010107204400fw_/http://www.midiman.net:80/m-audio/html/products/dio2496.htm
https://web.archive.org/web/20000530233805fw_/http://www.midiman.com:80/Html/products/dio2496.html
http://www.dancetech.com/item.cfm?threadid=243
part of the maudio delta family can be synched with other delta cards
INTRODUCTION
Professional digital transferring and mastering have never been as affordable and easily accessible as they are now with the Delta DiO 2496. With a host of pro features, the Delta DiO 2496 is ready for any and all optical and coaxial S/PDIF applications. Besides sporting both digital I/O formats (optical on TOSlink connectors, coaxial on gold-plated RCA connectors), the Delta DiO 2496 also provides a high-quality D/A converter which may be used for monitoring or mixdowns. All data paths support 24 bit 96kHz operation, and the D/A output channels are completely independent of the digital output channels making the Delta DiO 2496 a 2-in 4-out full-duplex card. Finally, the Delta DiO 2496 offers onboard digital mixing and routing, monitor control, SCMS (Serial Copy Management System) output on S/PDIF, and even multi-platform operation.
Midiman/M-Audio regularly updates the software drivers. They are posted to their Web site. (Search for the Delta-series drivers.) The drivers are compatible with almost all the audio software that's out there other than programs that make an effort to restrict themselves to proprietary hardware (like ProTools).
Features
    2-in, 4-out 24 bit/96kHz full-duplex audio interface on a half-size PCI card.
    S/PDIF inputs and outputs on Coaxial (RCA) and Optical (TOSlink) jacks.
    High-quality stereo analog output on RCA jacks, configurable as +4dB or -10dB.
    Built-in digital mixer allows the D/A converter to monitor digital inputs or act as its own independent stereo output.
    Measured D/A specs: 101dB (A-weighted) dynamic range, 0.002% THD @ 0dBFS.
    All data paths support up to 24 bit/96kHz performance.
    Drivers include: Windows 95/98, Windows NT, ASIO, ASIO2, Direct Sound, EASI, Multi-card 95/98 & Multi-card NT (up to 3 in a system), Gigasampler, Mac Sound Manager and Mac ASIO.
Which Card Should I Choose: Audiophile 2496 or the Delta DiO 2496?
M-Audio makes two fine two-channel digital audio interface cards: the Delta DiO 2496 and the M-Audio CO2.
(The Delta DiO 2496 is only a bit more expensive than the Audiophile 2496 and is equally as easy to install and use.)
Minimum System Requirements for PC
    Windows 95, 98, ME, 2000 or NT4; Linux (Windows 2000 MME compliant drivers will be available in late June)
    Pentium 200 MMX
    64 MB of PC100 RAM
    UDMA EIDE HDD
Minimum System Requirements for Mac:
    G4, G3 or G3 accelerator
    System 8.5.1 or above
    128 MB RAM for 96kHz operation
    96 MB RAM for 48kHz operation
« Last Edit: November 28, 2017, 02:42:11 PM by chrisNova777 »
