Author Topic: midiman multimixer 10 (1998?)  (Read 8964 times)
« on: November 07, 2017, 08:53:38 PM »
https://web.archive.org/web/20010215040956fw_/http://www.midiman.com:80/midiman/html/products/mixers.htm#multimixer 10
http://www.m-audio.jp/images/global/manuals/MultiMixer10_Manual.pdf
MultiMixer 10
10 Channel, Ultra-Quiet, Multimedia Mixer
$119.95 (msrp.)
MultiMixer 10 is an extremely low noise, professional quality, 10 channel stereo line mixer. The 6 panable inputs (1 through 6) enable you to place a sound source anywhere in the stereo field. Two of the six inputs (1 and 2) can have their gain set for either line level or microphone use. Four more channels (7,8,9, and 10) are unity gain inputs for which there are no volume or pan controls. These channels have to be controlled "at the source,so they are ideal for use as returns or AV ins.
Features:
• Ultra-quiet and superior headroom.
• Channels 1 through 6 have pan and gain controls. Channels 1 and 2 have 1/4" mono inputs and channels 3,4,5 and 6 have RCA (mono) inputs.
• Channels 7/8 ad 9/10 are unity gain stereo 1/8" inputs which are designed to be used as AV ins for your CD player or sound card.
• Built-in front headphone jack (1/8" stereo jack).
• Both dual RCA and 1/8" stereo multimedia main outs.
• Rugged steel construction.
Specifications:
• Freq. Response: 5 Hz to 100 kHz, +0, -1 dB
• THD: Better than .01% from 20 Hz to 20 kHz.
• Adj. Channel C/T: Better than -85 dB.
• Signal to Noise: >100 dB.
• Approximate Size: 7.1" X 3.7" X 1".
• Power supply: 9-volts ac wall adaptor: 300 milliamps.
« Last Edit: November 07, 2017, 09:20:49 PM by chrisNova777 »
