Author Topic: tascam fw-1082 (2006)  (Read 8502 times)
« on: November 27, 2017, 01:19:52 PM »
midi 2 IN/2OUT  + SPDIF + 8 analog inputs (2 /w inserts)
https://web.archive.org/web/20061109125337/http://www.tascam.com/Products/fw1082.html
https://web.archive.org/web/20061109125337/http://www.tascam.com/Press/Images/FW1082/FW1082_TopLg.jpg
10-in/4-out audio interface at 96kHz/24-bit
Nine 60mm touch-sensitive moving faders
Four balanced XLR / 1/4" TRS mic/line inputs with phantom power
Four balanced 1/4" TRS line inputs
1/4" TRS insert jacks for channels 1 & 2
S/PDIF stereo digital input and output
Balanced 1/4" TRS monitor outputs
Headphone output with level control
Two MIDI inputs and outputs
Assignable Footswitch jack
Eight channel strips with solo, mute, select, record arm indicator
Four assignable encoders control pan, aux level and EQ parameters
Transport controls, jog/shuttle wheel, and many other surface controls
Emulates Mackie HUI and Mackie Control in addition to the included native mode control plug ins
Includes GigaStudio 3 LE
Includes Steinberg Cubase LE 48-track 96kHz workstation software
Dimensions: 19.1"W x 3.25"H x 15.2"D
Weight: 14.3 lbs.
Compatible with the latest Intel Macs
The FW-1082 is a great choice for small studios, whether someone is just starting out or if they're upgrading their equipment. Its four microphone inputs, two with analog insert jacks, have phantom power for professional condenser microphones.
The TASCAM FW-1082 Audio/MIDI Interface and Control Surface from TASCAM and Frontier Design Group not only provides tons of audio and MIDI I/O to small studios, but offers a control surface with moving-faders for a previously unheard-of price. The FW-1082 features 10 inputs, including four balanced XLR mic inputs with phantom power. Two MIDI inputs and outputs are also included, plus S/PDIF digital I/O. Eight channel strips each feature a 60mm touch-sensitive moving fader and select/solo/mute buttons, and a moving master fader is also provided. The FW-1082 includes the latest TASCAM software bundle: Cubase LE 96kHz/48-track recording software and GigaStudio 3 LE streaming sampler.
Four additional line inputs and a S/PDIF stereo input add up to 10 inputs simultaneously, each at 96kHz/24-bit audio resolution. Two MIDI inputs and outputs are provided for 32 channels of MIDI synth playback or control. The control surface has nine 60mm touch-sensitive moving faders for silky-smooth control over channel level, pan or aux settings. Four encoders are also available for mix control, as well as transport and jog/shuttle controls. Stereo monitoring is included, and the FW-1082 even mixes signals internally for stand-alone use.
