Author Topic: alyseum U3-88c (2017)  (Read 8425 times)
« on: May 10, 2018, 08:46:36 AM »
www.alyseum.com U3-88c (2017)
First 8X8 MIDI interface through USB3.0!
With 5Gbps data transfer, an asynchronous mechanism which makes it possibel to send and receive data simultaneously (Full duplex), USB3.0 increases MIDI speed by getting the data transfer off the 1ms grid used in USB2.0 transfer.
In addition, using USB3.0, the computer gets the chance to prioritize the USB3.0 MIDI data transmission over other transactions.
This means latency and jitter are now truly insignificant between your computer and the MIDI port *. More....
U3-88c is Class compliant in USB 3.0 and offers driverless operation for WIN7 + 8 + 10 and OSX.
U3-88c is Class compliant in USB 2.0/1.0 and offers driverless operation for WIN XP + 7 + 8, iOS, OSX and Linux.
USB 3.0 Super-Speed is backward compatible with USB 2.0 devices; however, data transfer speeds are limited to USB 2.0 levels when these devices inter-operate.
Features:
   >    8 MIDI In/Out pairs interfacing to USB3.0 and USB 2.0/1.0
   >    DIP switches for fast and easy settings :
             1. Expansion up to 16 MIDI In/Out pairs.
             2. Running Status On/Off (compatibility with some synths requiring this setting).
             3. Multiple USB Endpoints On/Off.
   >    "All Notes Off" push button, for those quirky synths that get sometimes stuck.
   >    Backwards compatible with USB2.0/1.0 (with auto detect).
   >    LED activity indicator for each MIDI input and Output
   >    Ultra-compact rugged, robust, and stylized aluminium box.
   >    USB powered, no need external Power supply.
   >    Delivered with a USB3.0 blue cable  (1,8 meter / 70 inches size)
* We do not consider others latencies or jitter due to Computer processor power, Operating System, softwares load, .... and of course, which not depending of the MIDI Transport via USB.
