Author Topic: Esi MidiTerminal 4140 (2001)  (Read 9570 times)
« on: December 11, 2014, 04:41:34 AM »
www.esi-audio.com/products/miditerminal4140/
http://download.esi-audiotechnik.com/download/ESI/Miditerminal_4140/Miditerminal_4140-English.pdf
 The Miditerminal 4140 is the full featured 4-in/4-out, 64 channel MIDI interface for those who need an economic PC/MIDI solution. The 4140 works with any PC. Just hook it up to your computer's printer port and you're ready to go. The Miditerminal 4140 uses a parallel port. The parallel type MIDI Interface has much better MIDI timing compare to USB type MIDI Interface. And if that isn't enough, the miditerminal 4140 also has full SMPTE time code capability. Read and generate al frame rates for the ultimate in accurate synchronization. The Miditerminal 4140 support ESI's unique and powerful driver technology for perfect compatability with Windows XP, 2000, ME, 98SE.
Features
    4 In / 4 Out, 64 MIDI Channels
    Read & Write all frame rates 24, 25, 29.97, 30 Drop & Non-drop Send
    MTC to the computer for synchronization
    SMPTE Viewer and Generator software for convenient studio work
    Full LED Display
    8 large Activity Indicators
    Power-On, MIDI Thru function
    No AC adaptor required
    Compact and portable (13.5 x 8.8 x 2.7 cm)
    Uses Parallel (printer) Port
    Works with any PC
    Compatible with all major software (Cubase, Cakewalk, Logic Audio, - etc.)
    Advanced EGO-SYS ASIC technology
    Special Cable Included
    Microsoft Windows 98SE/ME/2000 & XP compatible
    Windows 3.1/95/98 driver also provided
« Last Edit: November 08, 2015, 09:15:44 PM by chrisNova777 »
