Author Topic: Soundcraft 6000 Mixer  (Read 5834 times)
« on: January 28, 2019, 08:23:09 PM »
http://www.muzines.co.uk/articles/soundcraft-6000-mixer/5826
SOUNDCRAFT 6000 SPECIFICATION
TOTAL HARMONIC DISTORTION:
Group (at 20dB above nominal level); <0.006% (1 kHz), <0.015% (10kHz)
Any output (+20dBu); <0.008% (1kHz), <0.02% (10kHz)
CROSSTALK:   1kHz   10kHz
Mic to line;   <-90dB   <-75dB
Line to mic;   <-105dB   <-94dB
Adjacent channel (line in/out);   <-100dB   <-90dB
Channel muting;   <-108dB   <-100dB
Fader kill;   <-85dB   <-84dB
Panpot isolation;   <-90dB   <-70dB
Routing (channel to group);   <-110dB   <-100dB
Aux send kill;   <-85dB   Not specified
NOISE:
(20kHz bandwidth, unweighted)
Mic input EIN (150 ohm source); -128dBu
Group noise (16 channels); -82dBu
Mix noise (16 channels); -87dBu
Aux noise (32 channel console); -84dBu
FREQUENCY RESPONSE:
Any input to any output; 20Hz to 20kHz (+0/-0.5dB)
INTERNAL HEADROOM:
Not less than 22dB at any point in console
Not less than 28dB at mix summing amps
Not less than 30dB at aux summing amps
INPUT AND OUTPUT IMPEDANCES:
Mic inputs; 2 kiloohm (balanced)
Line inputs; 20 kiloohm (balanced)
Outputs; 75 ohm
OUTPUT CAPABILITY:
Balanced outputs; Not less than 26dBu (600 ohm)
Control room outputs; Not less than 20dBu (600 ohm)
Other outputs; Not less than 22dBu (2 kiloohm)
