Author Topic: Cubase Score VST 3.5 (Sep 1997) requires win95 (not win3.1)  (Read 20874 times)
« on: December 16, 2014, 10:51:34 AM »
scroll down for requirements
http://www.soundonsound.com/sos/1997_articles/nov97/cubasevst.html
http://web.archive.org/web/19990501180030/http://edirol.com/music_equipment/audio_music_software/cubase.html
Cubase VST 3.5 (for Windows)
OS: Windows 95
CPU: Intel Pentium 100MHz
RAM:24MB RAM
GFX: 256 Colors 800x600
Rec CPU: Intel Pentium 166MHz
*** note that the requirements clearly indicate that this software is not to be run on a 486!
FEATURES & COMPATIBILITY
Cubase VST v3.5 is a true 32-bit native Windows 95 application, and will not run in 16-bit Windows (3.1 and earlier). The program supports multiple MIDI ports, and may use not only standard Windows MME-compatible soundcards, but also the new generation of multi-driver, multi-channel I/O cards, like the Korg 1212 and the forthcoming Lexicon and Event cards. Although Cubase VST will recognise multiple Windows MME soundcards, Steinberg do not recommend their use, because of the synchronisation difficulties that can occur between individual cards. Depending on the power of the PC, up to 32 audio tracks are available. Audio can be recorded directly into Cubase VST or imported in Windows WAV or Mac AIFF formats, and support is provided for MTC, MIDI Clock and SMPTE to synchronise external devices such as ADATs, stand-alone hard disk recorders, analogue tape decks and VTRs. Cubase VST offers an unlimited number of MIDI tracks to work with, and the MIDI timebase can be set to 96, 192 and 384ppqn (pulses per quarter note), which works out at 1/1536th of a whole note at maximum resolution.
from the back of the box; translated from german;
minimum requirements: windows 95, intel pentium 100Mhz, 24MB RAM, 256 Colors 800x600, Windows 95 compatible sound blaster, enhanced E-IDE or SCSI hard drive RECCOMENDED: pentium 166Mhz, 256 Colors 1024x768
other requirements found online on edirol.com website:
System Requirements
Windows
Pentium 133 MHz or faster
Minimum 16 MB RAM, recommended 32 MB RAM
Windows 95
MME or ASIO compatible sound card
   Macintosh
Apple Power Mac or compatible computer with 16-bit 44.1kHz audio capability or ASIO compatible sound card
Minimum 16 MB RAM, recommended 24 MB RAM
2nd-level cache required
System 7.5.3 or higher
Offline smilesdavis
those box covers are from the standard version fotos you found on worth"."
please fix this, cubase history is confusing enough as it is, especially in that era
« Last Edit: January 09, 2023, 08:01:58 AM by smilesdavis »
