Author Topic: AudioWerk8 (1997)  (Read 11617 times)
AudioWerk8 (1997)
« on: December 18, 2014, 02:35:22 AM »
http://www.midiguy.com/shwrm/frmemgc.shtml#anchorAW6
http://bertram-family.com/felix/projects/audiowerk-8.html
https://web.archive.org/web/19991127120451/http://emagic.de:80/english/products/hardware/aw8.html
AudioWerk2/8
Reliability & compatibility. PCI digital audio recording with the warmest sounding cards in the business.
One Audiowerk2 for mastering or internal mixing. One, two or three Audiowerk8 for additional mixing with an external console.
All Audiowerk cards can use either 2 analog or 2 digital inputs.
Audiowerk2 allows you to use the analog and digital outputs simultaneously and independently.
The digital output of Audiowerk8 cards is always parallel to the first analog output pair (can be used simultaneously but not independently).
Stacked systems must be wordclock synchronized between the cards via digital I/O. Therefore, the number of digital I/O's remains two (first card's input and last card's output).
The number of tracks doesn't depend on the number of cards, even one Audiowerk2 allows up to 32 stereo tracks with Logic Audio Platinum, 24 tracks are available with Logic Audio Gold and up to 16 tracks with Logic Audio Silver.
System Requirements Windows
Windows 95/98
Pentium 100
free PCI Slot
32 MB RAM
Multimedia compatible Hard disk (EIDE or SCSI)
Recommended:
Pentium II
64 MB RAM
UW SCSI Controller
Hard disk for Audio Files only
System Requirements Macintosh
PowerMacintosh
free PCI Slot
32 MB RAM
Recommended:
G3 Processor
64 MB RAM
UW SCSI Controller
Hard Disk Requirements
min. 1.5 MB/s Transfer Rate
max. 15 ms Average Access Time
(for Logic Audio: >3 MB/s and <10 ms)
JAZ Drives suitable for max. 16 tracks playback
Technical Data Audiowerk8 / Audiowerk2
PCI Card, 32 Bit Busmaster Technology
Depth 7"
Operating Systems: Windows 95/98 or Mac
Record Channels: 2
Playback Channels: 8 (Aw8) / 4 (Aw2)
Connectors: RCA, unbalanced
Nominal Level: -10 dBV
Max. Level (@ 0dBFS): 1.5 VRMS
Dynamic Range: > 90 dB (I-O, A weighted)
thd: < 0.006% (1 kHz @ 0 dBFS)
Frequency Range: 20 Hz to 20 kHz ± 0.5 dB
A/D Converter: 1 Bit Bitstream, 18 Bit equivalent
D/A Converter: 18 Bit
Oversampling: 128 times
Digital I/O Format: S/P DIF
Digital Audio Format: 16 Bit linear
Nominal Sample Rate: 44.1 kHz
Audiowerk8 only:
Sample Rate Range: 40-50 kHz, Resolution 1Hz
Continuous Calibration Technology (ext. Sync)
Up to 3 units stackable (24 Playback Channels)
Technical Data Audiowerk2
Depth 7"
Record Channels: 2
Playback Channels: 8 (AW8) / 4 (AW2)
Connectors: rca, unbalanced
Max. Level (@ 0dBFS): 1.5 vrms
a/d Converter: 1 Bit Bitstream, 18 Bit equivalent
d/a Converter: 18 Bit
Digital i/o Format: s/p dif
