Author Topic: connecting cdroms to sound blaster cards  (Read 9172 times)
« on: August 21, 2019, 06:30:26 PM »
The following chart shows which types of drives will work with which Creative
card.  To determine the EXACT CT number of a card, please look at both the CT
number printed on the board AND the CT number on the white sticker on the
back of the card.  If they do NOT agree, use the CT number on the sticker.
Please see the note at the end on exact drives and drivers for each of the
interfaces listed below:
Code: [Select]
          Card:     Panasonic  Sony  Mitsumi  SCSI   IDE
          CT1330   |   XXX   |     |         |     |
          CT1600   |   XXX   |     |         |     |
          CT1730   |   XXX   |     |         |     |
          CT1740   |   XXX   |     |         |     |
          CT1750   |   XXX   | XXX |   XXX   |     |
          CT1759   |   XXX   | XXX |   XXX   |     |
          CT1770   |         |     |         | XXX |
          CT1779   |         |     |         | XXX |
          CT2230   |   XXX   | XXX |   XXX   |     |
          CT2239   |   XXX   | XXX |   XXX   |     |
          CT2230C  |   XXX   |     |         |     |
          CT2239C  |   XXX   |     |         |     |
          CT2230S  |         | XXX |         |     |
          CT2239S  |         | XXX |         |     |
          CT2260   |   XXX   | XXX |   XXX   |     |
          CT2290   |   XXX   |     |         |     | XXX
          CT2291   |         |     |         |     | XXX
          CT2299   |   XXX   |     |         |     | XXX
          CT2740   |   XXX   |     |         |     |
          CT2749   |   XXX   |     |         |     |
          CT2760   |   XXX   | XXX |   XXX   |     |
          CT2760A  |   XXX   | XXX |   XXX   |     |
          CT2770   |   XXX   |     |         |     |
          CT2779   |   XXX   |     |         |     |
          CT2810   |         |     |         |     | XXX
          CT2839   |         |     |         |     | XXX
          CT2910   |   XXX   |     |         |     | XXX
          CT2911   |         |     |         |     | XXX
          CT2919   |   XXX   |     |         |     | XXX
          CT2929   |         |     |         |     | XXX
          CT2959   |         |     |         |     | XXX
          CT3110   |         |     |         |     | XXX
          CT3120   |         |     |         |     | XXX
          CT3600   |         |     |         |     | XXX
          CT3620   |         |     |         |     | XXX
          CT3780   |   XXX   | XXX |   XXX   |     |
          CT3900   |   XXX   |     |         |     | XXX
          CT3919   |         |     |         |     | XXX
          CT3930   |         |     |         |     | XXX
          CT3960   |         |     |         |     | XXX
          CT3980   |         |     |         |     | XXX
          CT3990   |         |     |         |     | XXX
The following cards have NO CD-ROM interface at all:
          CT1300, CT1310, CT1320, CT1350, CT5320, CT5330
Panasonic: single speed: Panasonic 521, 523, 531 (external)
           double speed: Creative CD200; Funai E2250, E2800; Panasonic 562
                         (req. driver from Panasonic), 563
           quad speed:   TEAC CD55 (req. driver from TEAC)
Sony: single speed: CDU-31A
      double speed: CDU-33A
Mitsumi: single speed: FX001
         double speed: FX001d
SCSI: see the SCSI-2.TXT file in Lib 7 / SB16 Files for a complete list of
      drives that have been tested with the current versions of the Adaptec
      EZ-SCSI software we are using (virtually any SCSI-2 CD-ROM drive should
      work though).
IDE:  double speed: Creative CD220E
      quad speed: Creative CD420E;  Funai E 2650UA, 2750UA;  Goldstar GCD 540,
                  R-542B, R-560B;  Hitachi CRD 7730B;  Mitsumi FX400, FX400D,
                  FX400E, FX600S;  NEC CDR 271, 272, 273;  Panasonic CR-574,
                  CR-581B, CR-581J, CR-581M;  Sanyo CRD-254P;  Sony 75E, 76E;
                  TEAC 56E (req. driver from TEAC); Toshiba XM-5302B
      hex speed: Creative CD620E
      8x speed: CD820E
      (Virtually any IDE CD-ROM drive should work, but MAY require a driver
      from the drive manufacturer).
NOTE:  Creative does NOT provide any support for drives that are marked as
requiring a driver from the manufacturer.
