Author Topic: graphic cards compatible with mojave (official from apple)  (Read 6623 times)
https://support.apple.com/en-us/HT208898
Make sure that your graphics card works with Mojave
Next, check to see if the graphics card in your Mac Pro is compatible. You can use System Information to find out which graphics card your Mac has:
    Press and hold the Option key while choosing Apple () menu > System Information.
    In the sidebar, select Graphics/Displays. If your graphics card is compatible, you see "Supported" next to the Metal entry. You can also note the name of your graphics card and see if it's in the list below.
These specific third-party graphics cards are Metal-capable and compatible with macOS Mojave on Mac Pro (Mid 2010) and Mac Pro (Mid 2012):
    MSI Gaming Radeon RX 560 128-bit 4GB GDRR5
    SAPPHIRE Radeon PULSE RX 580 8GB GDDR5
    SAPPHIRE Radeon HD 7950 Mac Edition
    NVIDIA Quadro K5000 for Mac
    NVIDIA GeForce GTX 680 Mac Edition
Some other third-party graphics cards* based on the following AMD GPU families might also be compatible with macOS Mojave on Mac Pro (Mid 2010) and Mac Pro (Mid 2012):
    AMD Radeon RX 560
    AMD Radeon RX 570
    AMD Radeon RX 580
    AMD Radeon Pro WX 7100
    AMD Radeon RX Vega 56
    AMD Radeon RX Vega 64
    AMD Radeon Pro WX 9100
    AMD Radeon Frontier Edition
If the graphics card in your Mac Pro isn't listed above, you need to install one that's compatible with macOS Mojave. If you need additional help, contact Apple Support.
* Third-party graphics cards vary, so you should check with the vendor of your specific graphics card for compatibility details.
