Author Topic: LG Ultrafine monitor (made by LG + Apple) requires mojave  (Read 7693 times)
« on: July 16, 2020, 05:49:52 PM »
https://www.iphoneincanada.ca/mac/apple-23-7-lg-ultrafine-4k-canada/
https://www.apple.com/ca/shop/product/HMUA2VC/A/lg-ultrafine-4k-display
A Mac with built-in USB-C or Thunderbolt 3 (USB-C) ports is required;
After ending sales of its older LG UltraFine 4K and 5K displays over the past couple months, Apple has now debuted a new 23.7-inch UltraFine 4K model, priced at $879.95 in Canada.
The new display has a 3840×2160 resolution with 8 million pixels and includes a single Thunderbolt 3 cable, offering up to 85W of charging for your MacBook Pro or MacBook Air with Thunderbolt 3 (USB-C) ports.
The previous 21.5-inch LG UltraFine 4K–which is no longer available–had a slightly higher 4069×2304 resolution.
The monitor has two Thunderbolt 3 (USB-C) ports, with one port capable of supporting another 4K display. There are three other USB-C ports (5 Gbps) to support your accessories and peripherals, to go with stereo speakers.
The new 23.7” LG UltraFine 4K includes an adjustable and removable stand, while it also supports VESA mounts.
Apple has detailed what devices can run the UltraFine 4K are various resolutions and refresh rates. Check out the list of system requirements and compatible Mac models below:
3840 x 2160 @ 60Hz
iMac Pro
iMac introduced in 2017 or later
Mac mini introduced in 2018
MacBook Pro introduced in 2016 or later
MacBook Air introduced in 2018
MacBook introduced in 2016 or later
iPad Pro with USB-C
3840 x 2160 @ 48Hz
MacBook introduced in 2015
3840 x 2160 @ 30Hz
Mac computers with Thunderbolt 2 ports using the Thunderbolt 3 to Thunderbolt 2 adapter
System Requirements
Operating System: macOS Mojave 10.14.5 or later
Connection: Thunderbolt 3–enabled Mac, USB-C–enabled Mac or iPad Pro
