Author Topic: Sekd Prodif Plus (1999?)  (Read 12669 times)
« on: December 28, 2014, 09:38:30 AM »
Description:
Sek'd Prodif Plus PCI audio card (also sold as the Marian Marc 2, see links below)
CD driver disc and 3-foot 75ohm SPDIF digital cable - included
We also have a 9' digital cable available, if needed. Just ask.
Specifications:
S/PDIF coaxial digital or professional AES/EBU input and output
TOSLINK digital optical input and output
1/4" TRS analog input and output
Jumper selectable +4dBu and -10dBV for analog I/O
Sample rates of 32, 44.1, 48, 64, 88.2, and 96 kHz
Digital I/O accepts bit rates from 8 to 24 bits
https://upload.wikimedia.org/wikipedia/commons/thumb/f/f9/Sekd-prodif-plus-soundcard-1999.jpg/621px-Sekd-prodif-plus-soundcard-1999.jpg
drivers
http://www.marian.de/files/prodifplus/
http://web.archive.org/web/20000620022011/http://www.sekd.com/archive.htm
mac driver:
http://web.archive.org/web/20000620022011/http://www.sekd.com/pd10a4.sit
install notes: http://web.archive.org/web/20000620022011/http://www.sekd.com/g4.html
  Mac Driver Install Notes
Example HR
>Enclosed is the V1.0a4 of the ProDIF drivers. This version does fix the
problem with the G4 where the SoundManager output and ASIO do not function.
>To install these drivers you have to drag the files "ProDif Plus" and
"ProDif Plus Thing" (or "ProDif 96 Pro" and "ProDif 96 Pro Thing") onto the
"System Folder" (German: "Systemordner") incon. The Finder will ask you if
these files should be put into the appropriate sub folders. Click "OK" in
this dialog. If the dialog does not show up something went wrong (i.e. the
system folder may be open).
>The "ProDif ASIO" file needs to be copied to the "ASIO drivers" folders of
every program that uses ASIO.
