Author Topic: old versions of clover here  (Read 21940 times)
« on: July 25, 2025, 12:00:58 AM »
https://mirrors.dotsrc.org/osdn/sfnet/c/cl/cloverefiboot/Installer/
https://mirrors.dotsrc.org/osdn/sfnet/c/cl/cloverefiboot/Bootable_ISO/
Clover_v2_r644.zip   6.2 MiB   2012-09-09 06:08:07
Clover_v2_r883.zip   10.4 MiB   2012-11-19 08:59:51
Clover_v2_r1000.zip   10.3 MiB   2013-01-15 06:02:21
Clover_v2_r1090.zip   9.9 MiB   2013-02-02 12:27:37
Clover_v2_r1208.zip   13.3 MiB   2013-03-30 08:39:31
Clover_v2_r1717.zip   16.0 MiB   2013-05-21 17:12:16
Clover_v2_r1995.zip   26.8 MiB   2013-08-30 15:20:54
Clover_v2k_r2082.zip   26.7 MiB   2013-09-13 16:01:09
Clover_v2k_r2999.zip   26.1 MiB   2014-11-06 05:26:04
Clover_v2k_r3050.zip   26.1 MiB   2014-12-06 06:15:22
Clover_v2.3k_r3156.zip   20.7 MiB   2015-02-02 18:20:12
Clover_v2.3k_r3333.zip   40.3 MiB   2016-01-19 18:30:20
Clover_v2.3k_r3577.zip   38.7 MiB   2016-06-24 17:35:25
Clover_v2.3k_r3911.zip   13.5 MiB   2016-11-07 20:20:23
Clover_v2.4k_r4003.zip   11.6 MiB   2017-02-08 19:07:25
Clover_v2.4k_r4128.zip   11.9 MiB   2017-07-25 17:34:00
Clover_v2.4k_r4200.zip   11.7 MiB   2017-09-08 17:15:07
Clover_v2.4k_r4243.zip   11.7 MiB   2017-10-07 16:44:08
Clover_v2.4k_r4334.zip   17.1 MiB   2017-12-08 04:50:10
Clover_v2.4k_r4369.zip   11.7 MiB   2018-01-07 05:40:42
Clover_v2.4k_r4392.zip   11.8 MiB   2018-01-26 05:20:16
Clover_v2.4k_r4497.zip   11.9 MiB   2018-05-23 19:58:38
Clover_v2.4k_r4586.zip   11.9 MiB   2018-06-29 03:23:53
Clover_v2.4k_r4700.zip   11.2 MiB   2018-10-10 05:02:08
Clover_v2.4k_r4813.zip   16.9 MiB   2018-12-20 16:26:24
Clover_v2.4k_r4895.zip   8.9 MiB   2019-03-02 18:33:15
Clover_v2.4k_r4920.zip   9.0 MiB   2019-04-15 17:43:05
Clover_v2.4k_r4945.zip   8.9 MiB   2019-06-05 14:41:32
Clover_v2.4k_r4988.zip   9.3 MiB   2019-07-11 04:00:14
Clover_v2.5k_r5018.zip   9.3 MiB   2019-07-16 18:41:58
Clover_v2.5k_r5045.zip   9.3 MiB   2019-08-10 18:03:00
Clover_v2.5k_r5058.zip   9.3 MiB   2019-08-26 19:21:25
Clover_v2.5k_r5070.zip   9.5 MiB   2019-09-05 16:25:22
https://www.insanelymac.com/forum/topic/317521-good-bye-clover-32/
according to this post ^^^ 32bit clover support was deprecated / discontinued around the end of 2016
http://web.archive.org/web/20130624023034/http://clover-wiki.zetam.org/Home
original clover website?
http://web.archive.org/web/20190322200217/https://clover-wiki.zetam.org/FAQ#Q:-I-got-boot0:error-or-b1f:error
ERROR FAQ here on web archive
http://web.archive.org/web/20120402161828/http://www.projectosx.com/forum/index.php?showtopic=2304
It is open source based on different projects: Chameleon, rEFIt, XNU, VirtualBox. The main is EDK2 latest revision.
I also want to thank all who help me with the development. Credits and copyrights remain in the sources.
http://cloverefiboot.sourceforge.net/
Main features:
- boot into 10.4 - 10.8 OSX, Windows EFI and Linux EFI
- boot into LegacyOS (WindowsXP, Linux, DOS) by their bootsectors
- this is EFI bootloader so it provides RuntimeServices for OS that impossible for Legacy Bootloaders
- mostly Clover do automatic detection of hardware and set all properties by default. But user can change them by config.plist
- with Clover you may restart into other OS from Startup Disk prefPane
- UUID written into config.plist will be the same as in OS
- SMBIOS will be corrected to standard 2.6
- ACPI will be corrected to standard 4.0. Custom DSDT will be loaded from booted partition or from EFI folder
- customizable RestartFix
- sleep/wake fixes
- PCIRootUID value
- Graphics Properties Injector for ATI, NVidia and Intel for wide range of supported cards. Also customizable.
- USB fix (LegacyOff, Ownership, Builtin, clock-id) up to USB 3.0
- HDA injector
- Ethernet builtin injector
- CPU turbo
- P- and C-states generator
- ACPI tables loading (SSDT-xx, APIC, BOOT, SLIC, SLIT, SRAT, UEFI...)
- extra kexts loading
- security mode for FireWire
- default boot after timeout
- customizable GUI: themes support, own icons, fonts.
- there is a possibility to implement national languages and fonts
- saving screenshots from GUI typing F10
- saving boot.log in OS and preboot.log from GUI by typing F2
