Author Topic: rewire v1.7 update (for use with reason 2.0 / 2.5 / 3.0)  (Read 5625 times)
« on: May 25, 2015, 01:20:07 PM »
https://www.propellerheads.se/download/updates_rewire/
updates for mac os x + windows only
im guessing this is from in between may 2005 + may 2006
because it mentions that the update is integrated with the 3.05 intel processor update
for reason which is from may 2006.
no update posted for mac os 9 (though it may exist? but not likely ..)
Offline 6track
Re: rewire v1.7 update (for use with reason 2.0 / 2.5 / 3.0)
« Reply #1 on: June 21, 2022, 03:25:04 AM »
Install_ReWire_&_Rex_for_WindowsVista
ReWire & Rex for Windows Vista
Please note: This installer is for Reason 3.0.4 users only. Reason version 4 users need not worry about this, it's all been taken care of.
https://web.archive.org/web/20081217213033/http://www.propellerheads.se/download/index.cfm?fuseaction=get_article&article=vista_installer
Install_ReWire_1_7_Mac
Install_ReWire_1_7_Win
ReWire 1.7
The ReWire 1.7 update brings dramatically improved sample loading times and compatibility with Intel Macs. If you use a PC, this update is for you. If you use a mac, you only need this update if you are not using Reason. For instance, if you use ReWire to hook up Ableton Live and Logic on an Intel Mac you should download this update.
Note: If you are using Reason 3.0.5, Reason version 4 or later, you do not need this update at all.
https://web.archive.org/web/20131103194406/http://www.propellerheads.se:80/download/updates_rewire/index.cfm
.dll ReWire&Rex from FL 20.7.3 (Windows)
.dll ReWire&Rex from Reaper 6.61 (Windows)
.dll ReWire&Rex from Reason 5 (Windows)
SetRexFolderPermissions.zip
Install_REX_Shared_Library_OS_9.sit
Install_REX_Shared_Library_OS_X.sit
Install_REX_Shared_Library.zip (Windows, 1.5.4))
Install_Rex_1_7_library.pkg.zip
REX_16_Installer.dmg
REX Shared Library update
For owners of Reason.
Download: Windows Mac OS X Mac OS 9
This update is required to be able to use REX files created in ReCycle 2.1 with Reason 2.5 and other applications. After downloading, please unpack the zip file or sit file and run the installer. This replaces the REX Shared Library with the latest version.
Note: If you have installed ReCycle 2.1 on your computer, you already have the latest REX Shared Library - there is no need to update.
http://www.propellerheads.se/download/index.cfm?fuseaction=get_article&article=rexsharedlibrary
REX Shared Library 1.7 – Universal Binary
For owners of Logic 9.1.2 and later
This update is required to be able to use REX files in the 64-bit version of Logic 9.1.2 or later. Please note that the 64-bit version no longer supports Power PC. After downloading, please run the “Install Rex library” installer. This replaces the REX Shared Library with the latest version.
Note: You currently don’t need this update unless you are using the 64-bit version of Logic 9.1.2 or later.
Note: The 1.17 installer does not work under OS X 10.8.3. If you want to install REX Shared Library under 10.8.3 please follow these steps:
Download and run the REX Shared Library 1.17
Download the SetRexFolderPermissions.zip file
Extract the zip
Double-click the SetRexFolderPermissions.command file
Terminal will open
Enter your computer password and press return
REX Shared Library 1.6 – Universal Binary
For owners of Reason, ReCycle & Logic
This update is required to be able to use REX files created in ReCycle 2.1 with Reason 3.0 and other applications like Logic 7.2. After downloading, please mount the disk image and run the installer. This replaces the REX Shared Library with the latest version.
Note: You don’t need this update if you are using Reason 3.0.5 or later.
Note: If you have installed ReCycle 2.1 on your computer, you already have the latest REX Shared Library – there is no need to update.
https://web.archive.org/web/20170726032755/https://www.propellerheads.se/support/user/recycle/general-recycle/rex-shared-library/
« Last Edit: June 23, 2022, 10:15:44 AM by 6track »
Offline 6track
« Reply #2 on: June 23, 2022, 09:43:11 AM »
+ Added above
« Last Edit: June 23, 2022, 10:08:51 AM by 6track »
Offline smilesdavis
« Reply #3 on: September 07, 2022, 02:25:36 PM »
« Last Edit: September 07, 2022, 11:18:13 PM by smilesdavis »
« Reply #4 on: September 28, 2023, 09:19:47 AM »
thanks guys
