Author Topic: 19" emagic AMT8 (1999) - pc serial / mac serial / USB 1.1?  (Read 16040 times)
Re: emagic AMT8 (1999) - SERIAL -
« Reply #1 on: January 18, 2022, 12:04:58 AM »
Offline foksadure
  • Stuck in 1997
« Reply #2 on: August 30, 2022, 06:11:18 PM »
Interesting teardown of the AMT8 at http://studiorepair.com/gallery/EES_Emagic/AMT8/index.html (pictures also from deepsonic.ch)
You can see that the AMT8/Unitor8 do share the same PCB, bar the missing components and firmware:
https://www.deepsonic.ch/deep/htm/emagic_amt8.php
https://www.deepsonic.ch/deep/htm/emagic_unitor8.php
Design by EES Technik für Musik, a now defunct german company that used to make MIDI retrofit kits, MIDI devices and OEM design/production (software protection dongles, MIDI gear) for other manufacturers from 1983 to 2008:
http://www.ees-musik.de/html_gb/main_gb.html
All metal case AMT8/Unitor8 were very seriously built compared to the very lightweight, cheap feeling Midex8. Both share a very similar electronic design though, the magic of AMT/LTB being in the coupling with their respective software companion, to offload timing sensitive processing to the hardware MIDI patchbay 8051 compatible MCU.
« Last Edit: August 31, 2022, 02:58:53 AM by foksadure »
AMT8 or Unitor8 preference pane software for osx 10.11+
« Reply #3 on: August 17, 2024, 12:54:41 AM »
https://www.potm.org/files/547cfa02636d2fed66cdc9841ec84420-39.php
https://www.potm.org/software/Downloads/
preferences pane?
An extensive re-write of the preference pane, with tons of great new features!
There is a new version of Unitor8/AMT8 Preference Pane available for OS X 10.10 (Yosemite), and OS X 10.11 (El Capitan), and future versions of OS X.
Computer Mode Input / Output Message Filtering
You can now configure the input and output message filters for Computer Mode.
Patch Mode Input / Output Message Filtering
You can now configure the input and output message filters for Patch Mode.
Patch Mode Program Change Configuration
You can now configure the Patch Selection Program Change Channel and Port.
You can enable or disable the Program Change configuration.
