Author Topic: 19" Roland S-330 (1988) MIDI digital sampler (RCA outputs)  (Read 63905 times)
Re: Roland S-330 (1987?) MIDI digital sampler
« Reply #1 on: July 16, 2017, 12:24:15 PM »
« Reply #2 on: July 16, 2017, 12:25:39 PM »
« Reply #3 on: September 24, 2017, 12:16:52 PM »
« Reply #4 on: April 08, 2018, 02:25:06 PM »
yamaha mu-01 mouse for Roland S-330 sampler (1987?)
« Reply #5 on: January 13, 2019, 05:01:38 AM »
Canon VG-100
Mitsubishi ML-10MA
Mitsubishi ML-11MA
Neos MS-10
Neos MS-10X
Neos MS-10Z
Philips VZ-1921
Sakhr MU-01
Victor HC-A704M
Wigmore MS2000
« Last Edit: February 23, 2023, 12:53:47 AM by chrisNova777 »
« Reply #6 on: January 14, 2019, 05:22:09 AM »
What is S-xxx?
Directx 9.0c or later
1.5  GHz processor
1GB RAM
50 MB free disk space
1 S-xxx hardware interface
3 Button or Wheel mouse
How does it work?
« Reply #7 on: January 14, 2019, 05:26:30 AM »
« Last Edit: January 14, 2019, 05:27:14 AM by chrisNova777 »
Re: Roland S-330 (1988) MIDI digital sampler (RCA outputs)
« Reply #9 on: April 23, 2019, 12:22:37 AM »
« Reply #10 on: June 26, 2019, 04:09:36 AM »
« Reply #11 on: August 01, 2019, 12:11:45 PM »
12-bit hit
ROLAND S330 SAMPLER
ROLAND AROUND IN THAT STUFF
THANKS FOR THE MEMORY
ONE CAREFUL OWNER
CONCLUSION
CHEAP AT TWICE THE PRICE
UPPING THE STAKES: THE S550
BAND IN A BOX: THE W30
« Reply #12 on: February 23, 2023, 12:51:29 AM »
 8)
