Author Topic: M-Audio DiO 2448 (1999) win95 compatible  (Read 9376 times)
« on: October 25, 2016, 09:18:51 PM »
http://web.archive.org/web/20010211110542/http://www.midiman.net:80/m-audio/html/dr/drdio48.htm
http://web.archive.org/web/20001214053000/http://www.midiman.net:80/m-audio/html/dr/drdelarc.htm
http://www.m-audio.jp/images/global/manuals/Dio2448_Manual.pdf
The DiO 2448 PCI Digital I/O Card combines Coaxial and Optical digital I/O with stereo analog outputs at a remarkably low price. It's perfect for interfacing to S/PDIF-capable equipment such as DAT machines, MiniDisc recorders, dedicated audio converters, and more. In addition, the built-in D/A converter provides analog audio output for monitoring incoming digital audio. Plug your CD-ROM or CD-R to the internal analog or digital connector, and use the DiO 2448 as your Windows Sound System card.
Features:
• 2-in, 2-out 24-bit/48kHz full-duplex PCI audio interface.
• S/PDIF inputs and outputs on coaxial (gold-plated RCA) and optical (TOSlink) jacks.
• Stereo analog output on gold-plated RCA jacks (consumer signal levels).
• On-board headers accept analog audio from internal CD-ROM players.
• On-board header accepts digital audio from internal CD-ROM players.
• D/A converter may be used to monitor digital input or output.
• Digital input may be bypassed directly to digital output (“audio thru” mode).
• Supports 44.1kHz and 48kHz sample rates.
• Windows 95/98 drivers.
Minimum System Requirements:
• Windows 95 or Windows 98
• Pentium 200 Mhz
• 32 MB of RAM
• UDMA EIDE or SCSI hard disk recommended
« Last Edit: November 28, 2017, 06:29:06 PM by chrisNova777 »
