Author Topic: midisport 2x2  (Read 7873 times)
midisport 2x2
« on: March 03, 2017, 09:47:49 PM »
http://web.archive.org/web/20031222222604/http://zzounds.com/item--THKMIMMS22
http://www.zzounds.com/item--THKMIMMS22
M-Audio MidiSport 2x2
MIDISPORT 2x2 is a multi-port MIDI interface for USB-equipped PC and Apple computers. MIDISPORT's high-speed USB (Universal Serial Bus) connection to the computer assures reliable, immediate MIDI transfers. Installation is a breeze - no computer disassembly, no jumpers to set, no I/O Addresses, IRQs, or DMA channels to configure! Expansion is just as easy - just plug in additional MIDISPORT units for more MIDI ports.
Features
2-in, 2-out MIDI Interface (32x32 MIDI channels).
High-speed connection to USB-equipped PC or Apple computers.
MIDI-activity indicators for each port.
Self-powered - requires no external power supply.
Comes with 6' USB cable.
"MIDI Thru" pushbutton allows you to play to your gear even when your computer is turned off - without having to disconnect cables.
Includes OMS drivers for Mac OS 8.6.
Windows 98 or higher compatible - true Plug-and-Play installation requires no IRQ, I/O Address, or DMA channel setup.
Extremely compact size.
System Requirements
Windows 98 and higher, or MAC OS 8.6 and higher
« Last Edit: January 21, 2018, 11:12:40 PM by chrisNova777 »
