Author Topic: Cubase VST 4.0 for macintosh  (Read 12662 times)
« on: March 05, 2017, 06:41:42 AM »
http://dlia.ir/Scientific/Magazines/SoundandMusic/Sound.On.Sound.Magazine.Sound.Music/1998/Cubase%20VST%20v4-SOS-Oct.pdf
*** the pdf above is no longer available (websites in IRAN blocked? perhaps?)
but the article can be viewed here : https://web.archive.org/web/20150607072229/http://www.soundonsound.com/sos/oct98/articles/cubase_vst4.html
article from october 1998, soundonsound
STEINBERG CUBASE VST v4.0 FOR APPLE MAC
The upgrade of Cubase to version 4.0 sees the software comprehensively overhauled -- and it's available in an optional 24-bit version for the first time. MARTIN WALKER temporarily changes platform for the next stage of the Cubase journey.
The biggest problem I had when writing this review was knowing where to start. Far from being a spit-and-polish upgrade, version 4.0 of Cubase VST for the Mac has undergone a complete overhaul, with a host of new features (sadly, PC users like myself will have to wait for these changes -- see the 'What about the PC version?' box). Along with all the changes, Steinberg have also launched another high-end version -- Cubase VST/24, which replaces Cubase Audio XT at the top of the Cubase hierarchy, above Cubase Score and the standard non-24-bit Cubase VST. The standard Cubase VST v4.0 was used for the purposes of this review, but see the '24-bit? Sounds Great!' box for more on the new flagship version and how it differs from the non-24-bit Cubase under scrutiny here.
Whether you buy the standard Cubase VST, Cubase Score or the 24-bit version, you get a CD-ROM containing all three applications -- but the associated Master floppy disk will only contain a licence for the one you've purchased. Two 'authorisation counts' are provided, and they will thankfully survive a hard disk defragmentation. I still personally prefer the dongle protection of the PC version, but most Mac users seem well used to having hard disk installs (whether or not they approve of the protection method).
THROUGH THE ARRANGE WINDOW...
Despite the changes to the Cubase range and the upgrade to the features within each version of the program, version 4.0 will still seem largely familiar to existing Cubase users, even those like myself who normally use the PC version. The heart of the program is still the first window you see when you launch it -- the Arrange window (see main screenshot). Nevertheless, there are lot of significant tweaks to this window. For a start, the restrictive 10-letter limit for both track and part names has been extended to 26 (no more cryptic abbreviations needed), and the entire dropdown menu structure has been re-organised. Most people will adjust fairly quickly and find familiar menu options elsewhere, although there are many new ones as well.
The Part Appearance options have been enhanced and rationalised -- both MIDI and Audio parts are now treated in the same way. You can view names, events, or both, and you can still decide what types of MIDI data will appear as events. A third and new option is 'Use Track Settings', and this introduces an extra 'N-E' track column where you can select name and event display independently for individual tracks, entire track classes (all Audio, or all MIDI for example), or every track in the arrangement. This versatility brings Cubase VST a little more in line with Logic Audio.
Tracks can now be resized independently in the vertical direction. You can change all sizes for a certain track class, which is ideal when you want big audio waveforms but small MIDI tracks, for example. Alternatively, you can zoom in on a single track when working on it, without losing all the others off the top and bottom of the screen.
Another way to keep the Arrange window more manageable is to use the new Folder Tracks -- a new class of track containing others, just like folders in MacOS (and, indeed, in Emagic's Logic Audio). Once you have created a new folder track, you can drag and drop any combination of MIDI, Drum or Audio tracks into it, which can then be collapsed into a single track (the screen display indicates the number of tracks within a folder by dividing the part displays into a number of horizontal strips). Folders can give a huge saving in screen space, and are ideal for drums, brass or string sections. You can still expand the folder at any time to view and edit each track individually, but the best thing is that you can edit the entire folder instead -- all the events will then appear in a single editor window.
FULL MARKS
However, the most obvious new item on the Arrange page is a small button labelled 'Marker'. This toggles a feature that many users have been requesting for a long time -- a Marker Track, which appears as an extra full-width horizontal strip directly above the ruler. At last you can add text such as 'Verse', 'Change to D#minor here', 'This bit needs re-doing', or 'Start fading here'. You can add Marker Parts by double-clicking between the left and right locators, or drawing them in with the pencil, and all the normal editing tools such as eraser, scissors and glue can be used. You can enter up to 26 letters in each marker, but even better, if you double-click on one, another window pops up where you can enter comments. This seems to have unlimited length, so it is perfectly possible to add a novel describing the historical and socio-political reasons for a particular key change.
Clicking on a marker moves the Song Position pointer (for quick navigating), while simultaneously holding down the Command key sets the left and right locators either side of the marker as well. You can also use Marker parts in conjunction with the new Range Selection tool (more on this later), to quickly select everything within the specified range. It is even possible to use Markers to move and copy entire sections of the Arrange page from one position to another -- ideal for quickly trying out different variations of verse, chorus, and middle eight.
BAR SNACKS
The Transport bar now has three size options: two horizontal sizes containing all the usual buttons, and a collapsible vertical one with three options. Useful as these are, more interesting is the new but confusingly named Toolbar, which even Steinberg's own publicity refers to, far more clearly, as a user-definable icon bar. You can hide or show this from an option in the Windows menu, and it defaults to having five icons for Rewind, Forward, Stop, Start, and Record. However, the Toolbar offers a lot more than just these functions, since the control icons it contains can be chosen from the Key Commands window (which is in turn located in the Preferences menu). Here, arranged in nine submenus, you will find every item from every main pull-down menu, as well as extensive transport bar options. You can redefine any of the existing keyboard shortcuts, assign them to a MIDI note, or to controller or program change messages, and/or give them an icon that then appears on the Toolbar. Many functions already have unique icons, but even if there isn't one for a function you want, you can choose from a selection of predefined ones. These new options will please everyone who prefers to use the same keyboard shortcuts in several different applications rather than a mouse, but it also means those who prefer mousing around can place all their most-used functions on the icon bar for one-click access.
MAKING AN INSPECTION
The Inspector, the section of the Arrange window containing track and part playback parameters, has been made more comprehensive in version 4.0. Partinfo now shows the start and end positions (which can be edited directly), and the Preferences dialogue box now has options to change volume and pan with pop-up horizontal faders, while another preference allows transpose to be adjusted from a pop-up mini keyboard. Audio tracks also have these additions (apart from transpose), and the volume and pan controls mirror the positions of the channel fader and pan controls in the Audio mixer. This is a useful way to make quick mix adjustments without having to open up any Mixer windows.
Clicking on the small button at the top right opens the Extended Inspector (see screenshot on page 100), which has extra options for MIDI tracks. Multi Out allows you to add extra Outs so that you can, for instance, play back a track through several MIDI channels simultaneously. Each added output has its own Inspector, so you can choose a different MIDI port or channel, give it a different name, transpose it, and so on -- this feature will certainly keep the Arrange page more manageable if you do a lot of doubling to fatten up sounds.
There are two Randomise boxes, which allow you to specify the amount (minimum and maximum) of random variation for any two parameters chosen from position, pitch, velocity, and length. Sadly, for anyone like me who instantly thought of using this feature to 'humanise' sequence data by slightly randomising the pitch of every note, random pitch offers only full-note transposition rather than pitch-bend nuances.
Two similar boxes allow Dynamic limits and filters to be applied to velocity or note values -- for instance, you could limit note values for a string section so that each instrument only receives the correct range of notes.
Many of the parameters shown in the Inspector can now be added as extra track columns (such as Volume, Pan, Transpose, and so on) which makes it far easier to see the value for every track at once than when using the Inspector. The Volume and Pan track columns also appear for audio tracks, and this does mean that basic audio and MIDI mixing can now be carried out from track columns, without opening up any other mixer windows (which will benefit those whose monitors are suffering pixel fatigue). It is even possible to carry out limited automation from these controls.
THE CUBASE RANGE -- SELECTED HIGHLIGHTS
* 15360 ppqn internal resolution
* 24-bit/96kHz capability with Cubase VST/24 and suitable hardware
* 64 audio channels -- 96 in Cubase VST/24
* ASIO support for additional outputs
* 16 group channels with effects and equalisers
* 8 auxiliary sends per channel (and 8 audio send effects)
* 4 insert effects per channel
* 4 master insert effects
* Non-destructive audio clips editor
* Folder tracks
* Complete marker navigation system
* Long track names (now up to 26 characters)
* Variable Transport display options
* User-definable Toolbar
* User-definable key commands
* Extended Inspector
* Improved drag and drop facilities
* Enhanced Toolbox (including Range Selection tool)
* New Controller Editor
* More Logical Presets (now savable to disk)
* Savable Grooves
* Savable Window sets
* Dedicated MIDI Tracks mixer
* Advanced score notation and printing (in Cubase Score and Cubase VST/24)
EDITING
Much more use is now made of graphical 'drag and drop' editing techniques; for example, parts or notes can be dragged onto the desktop (where they appear as a Part icon), and then dropped again later at another position. Notes dropped beyond the original end of a part automatically extend the part.
Also making editing easier is an enhanced Toolbox with various new tools. Three of them allow you to change Volume, Pan and Transpose directly by clicking on an individual MIDI Part. You can also apply Logical Edit presets or select a quantise groove for a part with two more tools. The speaker tool now allows you to audition individual parts, while the magnifying glass (which used to perform this function) now acts as a zoom control.
However, it is the new Range Selection tool that is the most interesting and useful, and this overcomes a former restriction when editing parts. Previously, you could only delete, move, and copy complete parts, and if for instance you wanted to grab a section of a song, and drop it later on in the arrangement, the entire part would be picked up. The only way to move a cross-part portion of a song was to make a global cut at the desired start and finish points, drag the cut portions across, and then glue the earlier cut parts back together. Range Selection allows you to draw a rectangle around any section of any combination of parts, and then perform any edit on this highlighted
portion -- and this applies to processing such as quantisation as well. Overall, this really streamlines editing, and I can't wait for it to appear in the PC version.
A new Controller Editor has been added, and this finally allows you to edit several controllers (such as volume, pitch-bend, and aftertouch) simultaneously on the same page. You simply select from the left-hand column the type of controller that you want to edit (holding down the Shift key for multiple selections), and the edit window is divided into a number of horizontal sections showing controller information ready for editing. Although MIDI notes can't be seen, you can edit velocity, which is a useful way to keep track of where the notes are in relation to other controller data.
Cubase's Logical Editor has always been under-used, and one possible reason for this is that even if you created useful presets, there were only 10 possible storage positions, and storing new ones once these were full wiped out the defaults. Version 4.0 now provides two sets of presets (24 in total), but even more usefully, they can now all be saved as disk files, and unlimited numbers of logical presets can be created, saved, and sorted into folders for global use by any song; so it's finally worth spending time on creating libraries of useful settings for future use.
In a similar fashion, Grooves are now saved on your hard disk, rather than with the song, so you can have unlimited numbers of these available as well (storage space permitting, of course). Another addition which makes life a little easier is the Quantise Groove Box. You can select any combination of MIDI parts, set up a cycle and suitable quantise value, and then once the Groove Box is selected, you can activate Pre-Listen and then hear the results of applying any groove file 'on the fly'. Timing, Velocity, and Duration sliders fine-tune the effect of the currently selected groove on these parameters, and once you are happy, you can click on 'Do It' to apply the final values to your data. You also access groove editing from here as well. The Groove Box certainly tidies up groove quantising functions, and makes them easier to access and use.
SETTING A TREND
At last! Window sets (known as Screensets to users of Emagic's Logic) have finally been added to Cubase, so that you can save and retrieve the sizes and locations of every open window on the screen. This includes the Arrange page, any open Editor, any Mixer, and the Audio Pool and Notepad. To create a new window set, you simply arrange everything on screen as you prefer, select 'New Window Set' from the Windows menu, specify various options, and then give it a name. Window sets are saved as part of your Preferences, so they are available on a global basis to any song.
You can recall any named set using the Windows menu again, but many people may prefer to enter the hugely expanded Preferences section mentioned earlier, and using the Key Commands window the first 15 window sets can be allocated keyboard shortcuts or even MIDI commands. I started by adding icons on the new user-definable bar for 'Mix All' (with MIDI, Audio, and Master channel windows open) and 'Arrange' (with just parts showing). Another useful related function is Track Views, which allows you to store and retrieve various arrangements of Track columns (minimal when arranging or mixing to get more parts on screen, and more comprehensive when adjusting play parameters, for example).
AUDIO & MIDI MIXING
The Audio Channel mixer is largely the same as before, although clicking on the 'FX' buttons now shows eight effects sends (arranged as two columns of four) instead of the previous four. However, there are now eight subgroup Channels as well, as well as an entirely separate Audio Group mixer. I did initially find this rather confusing, since the Audio Group mixer simply duplicates the controls for subgroups that have already been added to the end of the Channel mixer (moving a control on one panel causes the equivalent one on the other to move as well). Presumably this is so that you can quickly get at the subgroups without scrolling past the other channels.
You can route the output of a subgroup to any Output buss -- in most cases, you will want to route both 'sides' to the same stereo buss, although each side can be sent to a different output if desired. You can also alter the fader, EQ, and effects independently for each side of the subgroup by holding down the option key. However, this rapidly becomes unwieldy, since you need to open separate Effects/EQ windows for left and right sides, and if you once forget to hold down the option key when moving any control, the equivalent control on the other side will start moving as well. I did notice a tiny bug in the naming of groups -- 'L' and 'R' are appended to your chosen name, but if you re-open the text box, this happens again, resulting in names like 'Grp 5 L L'.
One big operational change is that MIDI channels now also have their own MIDI Track mixer. This looks very similar to the Audio one, and sports Fader (with meter alongside), Pan, Mute, and Solo buttons. These simply reflect the Inspector values (with the meter indicating MIDI velocity values), and send out MIDI controller values when changed. Ironically, this can cause confusion, since the MIDI Track Mixer is connected to Track Info in the Inspector, but not Part Info. If you make volume and pan changes for a single part using the Inspector, they will not be reflected in the Track Mixer -- Steinberg recommend setting all Inspector Part parameters to Off, removing any existing controller messages inside the parts, and then using the read/write automation facilities of the MIDI Track Mixer to record and play back all changes. A global Audio Mute button is also provided, in exactly the same way that the Audio mixer has a MIDI Mute button.
An Expand button for each MIDI mixer channel provides some extra functions: a selection of Yamaha XG and Roland GS controls are available (such as effects sends, attack, release, filter cutoff, and so on), and these send the appropriate SysEx messages. Once again, you can change these controls in real time for automation purposes.
Speaking of automation, there is one huge improvement for Audio as well as MIDI. In previous versions of Cubase VST, although clicking on the mixer 'Auto Write' button generated an Audio Mix track containing the automation data, there was no way to edit this except by grabbing a control and overwriting existing values. Now, not only does activating MIDI Auto Write generate a separate Track Mix track, but you can double-click on either the Audio Mix or Track Mix tracks to directly edit existing data, using the previously mentioned Controller Editor. Once again, by holding down the shift key when choosing what to display and edit, you can view multiple channels and parameters. When editing an Audio Mix track, the data appears as waveforms, so that you can clearly relate it to the superimposed controller information.
IMPRESSIONS
You really need at least a few weeks to fully explore the new options available in Cubase v4.0, but most things fall into place fairly quickly at a basic level. Although the reorganisation of the Menu structure does initially make it more difficult for long-term users to find things quickly, it doesn't take long to adapt, and functions do now seem to be in more logical places after the many rather piecemeal additions of the last few years' updates.
Users have been clamouring for some of the new features (such as long names, screensets and the automation editor) for ages, and these do make day-to-day operation a lot simpler. The Key Commands window and Icon bar will please many people, since they allow you to customise Cubase to suit your own personal way of working. In fact, flexibility seems to be one of the biggest features of version 4.0.
Overall this is a huge step forward for Cubase VST, and it will no doubt make a lot of people very happy. I have to say though that my favourite new feature is the Window sets. When the mixers disappear behind the Arrange page again I will no longer curse in frustration -- well, not until I return to Cubase on the PC, anyway!
WHAT ABOUT
THE PC VERSION?
PC users will have to wait for a while before they can get their hands on Cubase VST v4.0, though how long exactly is not currently clear. The latest word on the subject is that the PC version won't appear all at once. Version 3.6 will probably arrive in August, and then 3.7 later on this year. Quite which of the Mac version 4.0 features these interim PC updates will incorporate is hazy at present, and there is still some doubt over whether a full version 4.0 will appear for the PC at all. I'll keep you informed in PC Notes, but in the meantime, Mac owners have got something to gloat about again...
MANUAL MOAN
I know all the arguments about not cutting down any more rainforests, but sadly only a Getting Started manual is provided with Cubase v4.0; the other extensive remaining documentation is in on-line Adobe Acrobat format. To offset the inevitable murmurs of protest, Steinberg have bundled a tutorial CD-ROM with Cubase v4.0. This is in two parts: Getting Started (with 16 topics) and Working with Version 4.0 (with 14). Foolishly, I waded in at the deep end for this review, reading through the Getting Started manual for the new bits, and then exploring all the menu options within Cubase itself. However, I subsequently discovered a lot of previously undiscovered ways to use the new features in the CD-ROM tutorials. I wish there had been an equivalent when I first started with Cubase VST!
« Last Edit: February 12, 2019, 03:36:21 AM by chrisNova777 »
Offline Mixermap
Re: Cubase VST 4.0 for macintosh
« Reply #1 on: May 01, 2017, 09:47:36 AM »
I just bought a copy of Cubase VST Score 4 off ebay.
Complete, boxed and with registration docs still sealed.
The CD says "VST4.0 R1"
Since I have read on other forums the wrong info that VST 4 for the MAC does NOT use the old floppy copy protection system I want to confirm that instead it DOES come with a "master" floppy disk that must be used to authorise the hard drive install.
The installation routine writes onto the floppy.
This is what it says in the installation booklet.
I cannot test it because I do not have a MAC :D
Would be interesting to know if Steinberg has the same policy of replacing the floppy with a USB key on request in the same way as one can/could replace their  PC VST5 blue dongle for a USB elicencer.
The box says:
Absolute Minimum System Requirements
601/120 MHz Processor
32 MB RAM
256 K Second Level Cache
Mac OS System 7.6.1 or later.
However a note suggests that:
"...an Apple G3/300 MH, with 64 MB or more, would be very cool"
Cubase VST 4.1 For Macintosh *DEMO DOWNLOAD*
« Reply #2 on: February 12, 2019, 03:16:20 AM »
ftp://ftp.steinberg.net/Archives/Cubase_VST/Mac/Cubase_VST_41_2/Cubase%204.1%20DEMO%20WEB.hqx
heres a demo of Cubase 4.1 for Macintosh!
26 Mb in size
i guess this is from late 1998; when MacOS 8.5 was current but it is probably still compatible with os 7.61+ (as noted by MixerMap above)
« Last Edit: February 12, 2019, 03:18:20 AM by chrisNova777 »
Installing Cubase VST 4.0 for macintosh
« Reply #3 on: February 12, 2019, 03:39:56 AM »
https://www.sweetwater.com/sweetcare/articles/cubase-vst-of-g4-ibook-imac-dv-g3bronze-keyboard/
Article #3555 Updated on Apr 27, 2007 at 12:00 AM
1.. Mac OS 9 works best with Cubase because of Sound Manager issues with OS 8.6. There are actually 2 builds of 8.6. The later build of 8.6 works ok with Cubase but it is hard to tell which one you have…the earlier one or the later one. So, don’t take any chances, just go ahead and install OS 9, it will work better anyway.
2.. Download and install the Pace 2.0 Enabler from www.cubase.net. I know it says USB Floppy enabler and you more than likely don’t have a floppy drive, but you need to have this installed before you install Cubase since it is part of the copy protection system.
3.. Download and install OMS 2.3.8 (Open Music System) for MIDI implementation – it’s necessary if you’re using a USB MIDIinterface. If you don’t want to go out and buy a USB MIDI interface or if you do not want to use OMS, then you can use a Gee Three Stealth Serial Port (available for about $50.00) which allows you to use an older serial port MIDI interface. – More info at http://www.geethree.com/
4.. Install Cubase 4.1. If you have downloaded the update from the web or have a CD ROM with the word “Update” on it then you will need to have your original 4.0, 4.0r2 or 4.0r3 CD ROM handy…more on that later.
5. Before starting Cubase you should trash the Externalizer and the Tun-a Plug-ins from your VST Plug-ins folder. You won’t miss them and they may cause problems with Mac OS 9.
6.. Now you can double click on Cubase. You will first be asked to authorize, so go ahead and click on Authorize. Next you will be asked to insert a floppy key diskette so if you don’t have a floppy drive, go ahead and hit Cancel. Now you will get your challenge code. You can copy and paste this challenge code into an email and send it to Tracy@steinberg-na.com.
***If you want step by step instructions with pictures on how to
do all this, look on your 4.0 CD ROM for the “For Macs without Floppy Disks” folder and look inside that for the “No Floppy Install Details” document
* This is for US registered owners only please – don’t forget to
mention which level of Cubase you have: Standard, Score, or VST/24. You could also fill out your registration card and fax it to 818 678-5199 Attn: but don’t worry, you can use Cubase for 14 days before it expires. Just don’t wait till the 13th day to try and get a response code. For now, go and hit Cancel. Cubase will expand out and ask you to insert your 4.0 CD ROM. If you downloaded the update from the web or have a CD ROM with the
word “Update” on it then you will need to insert your original 4.0, 4.0r2 or 4.0r3 CD ROM. Then you will be asked to enter your Product Authorization code so enter that big long number on the red card that came with your original CD ROM.
** Entering the Response Code.
Until you get your Response code back from Steinberg, you can
use Cubase for 14 days. Every time you start, just hit Continue when it asks you if you want to permanently authorize. When you do get your Response code back you will then click on Authorize when Cubase starts up, then Cancel when it asks you for a floppy key diskette. The next dialog box you will see is the same one that gave you your Challenge code, so go ahead and enter your Response code in the blank space. Hit OK and now you are fully authorized.
« Reply #4 on: February 12, 2019, 05:18:18 AM »
https://www.macintoshrepository.org/1583-cubase-vst-4-0-tutorial-cd
tutoral cd here for Macintosh Cubase vst 4.0 (1998)
Offline smilesdavis
« Reply #5 on: October 10, 2022, 05:12:46 AM »
https://www.cnet.com/tech/computing/cubase-vst-floppy-drive-issues-a-work-around/
Cubase VST floppy drive issues: a work-around
CNET staff
Sept. 2, 2009 4:28 p.m. PT
Patrick La Roque reports that "Cubase VST 4.0 no longer recognizes its authorization when connected to an external hard drive and the Adaptec 2906 card. Since the G3 doesn't have a floppy drive and their master disk comes on a floppy....well, you get the picture."
Clifford Mould had a similar problem. However, he found that the Pace USB Floppy Expander (mentioned here last time) solved it, when used with an Imation SuperDisk. "Previously Cubase simply would not see the drive at all."
An alternative is to upgrade to Cubase's 4.03, which will allow registration over the net. (Thanks, Chris Fowler.)
PACE Anti-Piracyís USB Floppy Enabler Version 2.0
A Floppy Emulator for Power Macintosh G3 and G4 Computers
https://web.archive.org/web/20001006065250/http://www.paceap.com/usb_enabler.html
https://web.archive.org/web/20001001025729/http://www.paceap.com/iesite/hm_dlusbdriverf_frame.html
(bottom of page is download link)
« Last Edit: October 11, 2022, 11:28:09 AM by smilesdavis »
