Author Topic: lexicon alpha (2003)  (Read 8624 times)
« on: March 06, 2017, 10:19:16 PM »
http://lexiconpro.com/en/products/alpha
http://rdn.harmanpro.com/product_documents/documents/844_1330471348/LamOmegAlph_original.pdf
http://www.musiciansfriend.com/pro-audio/lexicon-alpha-usb-desktop-recording-studio
http://www.guitarcenter.com/Lexicon/Alpha-USB-Desktop-Recording-Studio-1274034482852.gc
Mac® Operating System: Mac OS X Version 10.2.8 or higher;
Processor: Power Macintosh G4 450 MHz or faster; RAM: 256 MB (512
recommended); Hard Disk Space: Multiple Gigabytes. 180 MB for application,
USB Port:* USB or USB 2
A compact, USB-powered interface with Lexicon's world-renowned audio quality.
Like the Omega and Lambda, the Lexicon Alpha USB Audio Interface is a complete portable desktop recording studio. It offers a 2x2x2 USB I/O mixer which is powered directly from the USB bus. You can be connected to the XLR inputs and the 1/4" balanced line inputs at all times while controlling input levels and monitoring from the front panel. The front panel also offers a Hi-Z instrument input and a 1/8" headphone amplifier output suitable for all headphone types. Alpha ships with Steinberg Cubase LE recording/editing software and Lexicon Pantheon VST reverb plug-in.
Cubase LE offers 48 tracks of tracking, supports up to 8 VST instruments, and is compatible with both VST system link and Rewire 2. The Lexicon Pantheon VST reverb plug-in offers 35 factory presets and 6 reverb types and lets you edit 16 parameters per reverb type.
FEATURES
2-channel USB interface
16-bit/44.1kHz to 24-bit/48kHz audio
One XLR microphone input
2 TRS line inputs
2 TRS and RCA line outs
Hi-Z instrument input (front panel)
1/8" headphone jack
Zero-latency direct monitoring
USB bus powered
Input level controls with peak meters
Record anywhere you can carry your laptop! Studio-quality hardware and powerful software that turns your PC or Mac® into a 24-bit recording studio.
ALPHA STUDIO
The Alpha™ Desktop Recording Studio is extremely compact, yet it gives you the features needed to get professional recording results anywhere! Designed with many of the same features found in professional studios, Alpha Studio is your complete recording solution: a USB powered I/O mixer with Cubase® LE 5, the popular recording production suite from Steinberg®, and our acclaimed Lexicon® Pantheon™ VST® reverb plug-in. A dual-input, 2-bus, 2-output USB I/O mixer with extra high-impedance instrument input and separate headphone output gives you the freedom to not only record but also mix anywhere.
More Details
FOUR INPUTS: RECORD UP TO TWO TRACKS AT ONCE!
Stereo line inputs for keyboards, drum machines or analog output of a CD/MP3 player. RF-filtered TRS active-balanced inputs accept either balanced or unbalanced signals.
Low-noise mic preamp with balanced XLR inputs.
High-impedance front panel input for electric guitar or bass.
PROFESSIONAL MIXER FEATURES
Separate mic and line level input controls with individual peak indicators.
Monitor mix control for balancing an audio source between live input and playback mix level while recording. Can be switched to stereo or mono.
High-powered headphone amp offers ultra-clear fidelity while delivering ample power for any type of headphones.
RF-filtered and TRS balanced Line outputs for speaker monitoring.
USB POWERED
Connect to your computer with the included USB cable. No need for a power supply…so you can record anywhere you can take your laptop.
Videos
USB POWERED
« Last Edit: December 17, 2017, 10:26:29 AM by chrisNova777 »
