Author Topic: geethree stealth serial port for power macintosh g3 B&W + power mac g4  (Read 15210 times)
http://web.archive.org/web/20010815150710/http://www.opcode.com/products/stealthport/
https://web.archive.org/web/20220110173752/http://geethree.com/downloads/index.html
http://www.atpm.com/6.08/stealth.shtml
the g4 stealth comes in a variety of models made specificly to match different mac models - this page outlines the differences and helps you to recognize these models and informs you of their compatibility
Powermac G4 (AGP Graphics) stealth Version becoming somewhat rare
Features
Download Stealth Data Sheet
(164K, PDF file)
The Stealth Serial Port provides a fully compatible serial port for you new Mac. Unlike USB-to-serial adapters, the Stealth Serial Port works with Localtalk, MIDI, any serial printer and virtually any other Mac serial peripheral. We back this compatibility with a money-back guarantee.
Compatible
- Functions just like a standard Mac serial port, including LocalTalk
- Hardware based on the same serial chipset found on earlier Power Macs
- No new drivers needed - old style drivers and Comm Toolbox supported
- Supports externally clocked serial peripherals such as serial printers and MIDI devices
- Standard mini-DIN8 connector
Simple
- Installs in minutes
- Uses internal modem slot, keeping PCI slots open
Great value
- Under $50
- 30-day money-back guarantee
System requirements
Open modem slot (no internal modem) - all models
Stealth Serial Port for G4
- Power Macintosh G4 Dual Processor (450, 500 MHz)
- Power Macintosh G4 AGP graphics (350, 400, 450 or 500 MHz.)
Stealth Serial Port for G3
- Power Macintosh Blue G3
- Power Macintosh G4 with PCI graphics
Stealth Serilal Port for iMac
- iMac rev A-D (233-333 Mhz.)
there are quite a few different types of these so lets go thru them
Powermac G3/G4 (PCI Graphics) Version even more rare + hard to find now, 2 revisions of this type
due to the visual nature of this type, these are often discarded by computer techs + people who think its just a lousy modem. (i personally have thrown a few out before i learned what they were) if you see any type of grey/ata ribbon looking cable on the right side of the case, going to the rear of the case this is most likely
a serial adapter, either a stealth by geethree or a gport/g3port by griffin
first version was for the B&W powermac G3, which was also compatible with the first edition G4, the "yikes!" g4
this version is visually different from the other SQUARE board.. it is a long rectangular smaller board + shorter cable + port adapter
"connect your serial peripherals to the blue power macintosh g3"
there was also a version for the imac
How can I tell what revision iMac I have? Does the Stealth Serial Port for the iMac also work on the new iMac DV?
The Stealth Serial Port for the iMac works on revisions A-D of the iMac.
This covers all models of the iMacs (including the flavors) with processor speeds from 233MHz -> to 333 MHz.
The new iMac DV and iMac - 350MHz. are based on a new logic board. The modem slot on these machines is very difficult to access and the hole for the modem jack is not large enough to accommodate a serial port. Sorry.
data sheet (in macbinary format - decode with stuffit expander)
http://web.archive.org/web/20001217235000/http://www.geethree.com/StealthSerialPort.pdf.bin
driver download:
http://web.archive.org/web/20010212074421/http://www.geethree.com/Stealth.sea.hqx
FAQ:
http://web.archive.org/web/20010303011548/http://geethree.com/supportstealth.html
which g4 needs which serial port?
http://web.archive.org/web/20010212034047/http://www.geethree.com/whichg4.html
Re: geethree stealth serial port for power macintosh g3 B&W + power mac g4
« Reply #1 on: February 26, 2017, 07:09:04 AM »
small note re: the powermac g5 stealth port compatibility
previously i had wrote that this was only compatible with the "FX" type G5's from 2004..
ive just learned that this is not entirely accurate as there are one ore more models from 2003 (such as my powermac g5 single 1.8ghz) that also use the same type of modem port  (which is the bassis for the requirement, as it needs to physically fit in the slot of course, duh )
Compatibility
G5 Machines released after 6/04 with the **newest Modem slot this item will not work
https://www.insanely-great.com/3085/stealth-serial-port-now-g5-compatible
http://www.macworld.com/article/1029431/stealth.html
http://web.archive.org/web/20060326074940/http://www.geethree.com/products/index.html
