Author Topic: Reason 11 (2019?) minimum requirements - Requires 10.11+  (Read 2696 times)
« on: December 06, 2019, 12:45:18 PM »
System Requirements
https://www.reasonstudios.com/en/reason/new
MacOS:
Fast, stable internet connection for installation and registration
Intel Mac with multi-core processor
4 GB RAM (8 GB or more recommended for large ReFills or Rack Extensions)
4 GB free system disk space required, plus 8 GB for optional content. Additionally, program may use up to 20 GB scratch disk space
Mac OS X 10.11 El Capitan (2015) or later (64-bit)
Monitor with at least 1280x768 resolution
CoreAudio compliant audio interface or built-in audio hardware
MIDI interface and a MIDI keyboard recommended
For using Reason as a VST Plugin, a DAW host with VST3 support is required
For using Reason as an AU plugin, a DAW host with AUv2 support is required
Windows:
Intel or AMD multi-core processor
Windows 7 (2009) or later (64-bit)
Audio Interface with ASIO driver
System Requirements
macOS
Mac OS X 10.11 or later (64-bit)
For using Reason as a VST Plugin, a host with VST3 support is required
For using Reason as an AU plugin, a host with AUv2 support is required
For using Reason as an AAX plugin, Pro Tools 12 or later is required
Windows
Windows 7 or later (64-bit)
Reason 11 reccommends MacOS Catalina 10.5.x or Windows 10
« Reply #1 on: May 17, 2021, 12:13:45 AM »
https://help.reasonstudios.com/hc/en-us/articles/360002215694-What-are-the-recommended-system-specifications-for-Reason-10-
macOS:
Fast and stable Internet connection for installation and registration required!
Intel Mac i5/i7/i9/Xeon with multi-core processor with at least 4000 CPU Benchmark points (see cpubenchmark). More physical cores highly recommended!
8 GB RAM or more
40 GB free hard disk space or more on the system drive. (The full Reason installation requires a minimum of 5+8 GB free system drive disk space. Any additional external Rack Extension devices and/or external ReFills of course demand a larger hard disk)
macOS Catalina
Monitor with at least 1280 x 768 resolution
CoreAudio compliant audio interface (or built-in audio hardware)
For using Reason as a Plugin, a DAW host with VST3 and/or AUv2 and/or AAX support is required
Windows:
Fast, stable internet connection for installation and registration required!
Intel i3/i5/i7/i9/Xeon multil-core CPU or equivalent multi-core AMD processor and at least 4000 CPU Benchmark points (see cpubenchmark). More physical cores highly recommended!
8 GB RAM or more
Windows 10 (64-bit)
For using Reason as a Plugin, a DAW host with VST3 and/or AAX support is required
