Author Topic: 19" Opcode Studio 64x (1997) not compatible with windows 98SE  (Read 12555 times)
« on: February 05, 2022, 09:28:13 AM »
https://web.archive.org/web/20030508205945/http://www.opcode.com/downloads/studiox.shtml
http://web.archive.org/web/19970213000349/http://www.opcode.com/products/cross_plat_hardware/studio64x.html
*** not compatible with Windows 98SE - only win98 first edition
*** there is a 3rd party developed driver for XP see this thread: http://www.oldschooldaw.com/forums/index.php/topic,7330.0.html
NOW AVAILABLE!
Take control of your Windows or Macintosh MIDI studio with Opcode's new Studio 64X MIDI interface. First in Opcode's new line of Studio X cross-platform interfaces, the Studio 64X is designed to work with both Macintosh and Windows computers.   [ Studio 64X Image]
The Studio 64X has 4 MIDI INs, 6 MIDI OUTs, 64 MIDI channels, full SMPTE synchronization, and powerful MIDI patchbay features, giving you total control over your MIDI studio. With its competitive price and solid features, the Studio 64X redefines the standard for MIDI interfaces! The Studio 64X is also OMS compatible for total integration with any OMS compatible application.
Studio 64X Feature List:
Connects to a Mac or PC at the same time--no switches to change
Automatically detects Mac or PC
4 IN x 6 OUT, 64 channels, and full SMPTE support
Powerful MIDI Patchbay
Easy one-button control of all features from the front panel
Works with notebook, laptop, and desktop computers
Rock solid Opcode reliability
Offline joethelion
Re: Opcode Studio 64x (1997) not compatible with windows 98SE
« Reply #1 on: February 12, 2022, 08:46:27 AM »
Hello Chris and all :)
Many thanks for creating and sustaining this wonderful treasure trove ...
I've not been able to contribute as yet, so having some potentially useful experience in this Opcode issue, I thought I might now be able to help. I'm not very accomplished currently, so please bear that in mind.
Nonetheless, I have no doubt the 64x can be used properly, fully functioning in 98SE via an onboard serial port and/or or via a suitable USB-Serial adapter.
I still have a pair of 64x's, which were once my midi mainstay on 98SE and then XPPro. I put them aside when I encountered too many sysex problems with the latter-day Gibson XP driver. I plan to put them to use again this summer. I'm building a 98SE machine, so I've had to re-visit/re-learn a great deal.
I was fortunate to find a little-used 775/865 MB with 98 chipset drivers, allowing me to fully use a (new) SeaSound, with an RME Digi 96 and the rare Audioterminal AT010. I'm planning around Cubase and/or SX/Nuendo, hoping to use 'System-Link' via ADAT concurrently with independent XP and Win 7 machines, via RME 9636/52's. I hope to achieve system-wide compatibility for concurrent operation of W98SE, XPProSP2 and Win7 SP1. I'll surely find out the hard way ... :)
It seems probable vintage serial midi gear can potentially be used on any MB with a Serial Port and/or via a USB-Serial adapter, on any Win OS; however, I doubt any sysex use with vintage gear could be viable post-XP, simply because program software will not have been developed.
I guess serial ports are now scarcer on contemporary MB; however, there are plenty of server boards. I know little of 'virtualisation'. I do not know if serial hardware drivers can function via VM's. Given Serial-MIDI is so fundamental and not complex; and given, the retro-gamers use joysticks via USB/MIDI serial game ports on old MB's and sound-cards, or via VM's, it seems there remains much potential for using vintage serial midi gear with modern OS's ...
I'm interested in what others more experienced think/know.
I recently discovered some notes I made 20 years ago. They may help those re-visiting 98SE Serial Midi/Daws, generally; and especially, with Opcode gear. Understanding how win 98SE installs/handles/assigns Com Ports is the key issue. Please bear in mind these notes concern a quite advanced setup (at that time). Some comments are not directly relevant; however, they illustrate a meticulous approach is required for Opcode in Win 98SE.
Kind regards,
JTL
Quote:
"64X - Important Install Notes 30/01/02
W98SE, CWPA9, Fujitsu P2-233/64Mb, PCI-ISA, ATX/PS2, Parallel & Serial, Crystal sound-card, ATX/Serial trackball kbd, Belkin FU012x2 and modem.
Both 64x on Serial Ports ... one via onboard serial, one via USB-Serial interface.
1.  Despite inference otherwise on Opcode's web site, the 64x can be installed properly, fully functioning on Win 98SE. It cannot with full sysex on XP, but plain midi note code is OK bi-directional with the Gibson driver and with fully functioning/freestanding patchbay.
2.  Installation process and Com ports setup must be as follows:
2.1 PC must be setup with Com 1 for first 64x and Com 2 for second 64x - and whilst no other Com Ports are installed.
ie: From a clean install, or having removed all Com ports beforehand.
NB: When some Com ports are removed via Device Manager, leaving others behind, they cannot subsequently be re-installed to the same port address (ie: Com 3, 4 etc) since Windows will skip any previously used port numbers and use the next free setting - such that prior Com 3 would become Com 4 etc (causing on-going driver code/addressing conflict.)
3. If problems arise on installing 64x, remove all Com ports from Device Manager and physically remove all coms hardware and associated applications/software. (Note directories/folders of all Coms gear beforehand to enable total removal of all related code) ...
Then let Windows re-install Com 1 & 2 from scratch on re-boot.
4. Install Belkin FU012x2 to Com 3, then Modem to Com 4.
(Do not install ISA Serial-Parallel card. Whilst it can be installed satisfactorily to provide another serial port, doing so leads to far too many Port Address/IRQ conflicts installing/setting up the 64x's.)
5. Kbd/trackball must be connected via Belkin FU012x2 serial port on Com3. It will be recognised as a Human Interface Device and HID Compliant Mouse ... But a PS/2 mouse must be used for setting up, since the trackball can't be used until the Belkin 12x2 is installed, as the on-board serial port is best used for first 64x.
6. The Modem must not be physically installed until Belkin FU012x2 has been installed and set up on Com3. Windows will otherwise detect the modem and assign it to Com 3. Setting up the 12x2 is only possible (at this time) by using the drivers for Windows ME.
7. Most importantly, the Opcode software must be installed whilst only Com Ports 1&2 are installed ... Do not follow the Win95 setup instructions in the 64x Help file, which is to install via Ctrl Panel/Add New Hardware/Manual Install/Sound,Video, Game Controllers ...
Install 64x directly via Setup.exe on the Opcode 64x driver floppy.
8. Any other approach means the 64x Patch Bay prog will not properly integrate with the basic drivers. The only fix is to remove all the Opcode entries in Windows\System.Ini, then remove the drivers from Windows\System, then configure all Com ports as above, before otherwise having to do it all over again !!!!
9. Only install one 64x on Com 1 initially (selecting Drivers, Patch Bay, Help Diag etc from the from setup menu).
9.1 When installing the second 64x to Com 2 via 12x2 select the 'Second Interface' option.
9.2 Ensure correct Com port configuration is set as Windows standard default ie: first 64x on Com 1 - IRQ 04, I/O 3F8, and second on Com 2 - IRQ 03, I/O 2F8.
10. Install CWPA before 64x's and ensure 64x User Program 3 on front panel is straight MIDI In to MIDI Out ie: 1-1, 2-2, 3-3, 4-4. "
END QUOTE.
« Reply #2 on: March 20, 2023, 12:36:06 AM »
http://www.hitsquad.com/smm/wwwboard/messages/58780.html
this page details how the 64x can be made to work on win98SE by installing earlier version of windows then upgrading??
also details a problem to do with aPM (advanced power managment)
also details a problem with 815 chipsets
Re: 19" Opcode Studio 64x (1997) not compatible with windows 98SE
« Reply #3 on: September 08, 2023, 10:43:01 AM »
http://web.archive.org/web/20050110121213/http://www.marting.demon.co.uk:80/interface/winfixes.html
this page says to disable ACPI in bios will fix it immediately re: opcode vs win98SE
so i hope all you win98SE people have that setting in your bios! i have tried the regedit fix + goten it to work using that fix.. but apparently its even easier if u can disable ACPI in the bios
ï Many of you will have noticed that Opcode interfaces suddenly stopped working under Windows 98SE/ME. However some industrious types have come up with a few solutions that may be of use.
1. Turn off ACPI
Most PC BIOS setting allow you to disable ACPI (a power rmanagement feature of Windows). Generally this simple fix will enable your interface once more.
-Enter the BIOS on bootup - usually by hitting [delete] or a fuction key on startup. Your PC will show a line on bootup saying something like "Press Delete to enter Setup"
Once you are in the BIOS the setting varies from machine to machine. On my PC (Award BIOS)  I chose the "Power Management Setup" Menu. Then there is an option for ACPI Function enable/disable. Turn it off and reboot - chance are you will be up and running .
-Some PC owners will find they cannot disable ACPI in the BIOS. This is where you have to get quite a bit more involved...
The following two methods have been emailed to me - I haven't tried them so it's at your own risk ! Worst case scenario you'll have to reinstall Windows but this is unlikely.
Credit to Robert and Jupiter for the tips !
2. Manual alteration of Power Management
-Run regedit ( start menu > run >type "regedit")
-go in: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\VxD\VCOMM.
-At your right look for the EnablePowerManagement line,you will see a value of 01 00 00 00 which is for on select the first digit and key in 00 00 00 00 which is for off.
-Close regedit and shut down the computer and interface for a while for a cold boot.
-Restart the computer and interface and you should be able to see it work.
If you still have problems try this also: go in windows/system run MKcompat.exe in file menu/choose program choose 64x.exe.(or whatever interface you have) then go in file/advance options check the delay com handshake box, save, reboot. So i hope it will solve your problems as it solve mine. Spread the good news and have a laugh at the face of theses opcode/gibson guys!
3. System Tweakery
-Load your win9x cd and extract the following files from cab 50 to BOTH: c\windows\system\ and... c\windows\system\vmm32\
The files to extract: vcomm.vxd, vdmad.vxd, configmg.vxd, vdd.vxd, vmouse.vxd, ntkern.vxd, vflatd.vxd,
Normally these files can be found on the win98 cd inside cab50 (depends on which version you have...just check the other cabs until you find the files). The files above all seems to have been replaced by vmm32.dll in a win98SE system. !!!! NEVER EVER DELETE THE VMM32.DLL!!!! You dont want to reinstall your computer....
Hope One of the Above Helps !!
