Author Topic: -nehalem_error_disable fixes AppleTyMCEDriver.kext SMBIOS kernel panic  (Read 6519 times)
command line switch boot arg for chameleon
AppleTyMCEDriver.kext controls the relationship between the OS and ECC RAM.
If you do not have ECC RAM, and you use the SMBIOS of a Mac that does,
then you will experience a KP on boot.
This can be avoided if you boot with -nehalem_error_disable
worked for me just now on a box with mountain lion 10.8.* and chameleon
not sure if it will work with clover etc
documented here: https://dortania.github.io/docs/latest/Configuration.html
