Author Topic: roland s- series samplers  (Read 338549 times)
0 Members and 15 Guests are viewing this topic.
« on: March 26, 2015, 08:05:01 PM »
E-mu products | Ensoniq Products | Akai "S" Series | Akai MPCs | Drum Machines | Roland JV Addons | early 90s Synths | late 80s synths | Roland Samplers
non-illustrated
MKS-100 (1986) http://www.oldschooldaw.com/forums/index.php?topic=2716 QD
S-10 (1986) http://www.oldschooldaw.com/forums/index.php?topic=2099.0 QD
S-50 (1986) http://www.oldschooldaw.com/forums/index.php?topic=3440 DS/DD
S-220 (1987) http://www.oldschooldaw.com/forums/index.php?topic=2866.0 QD
S-330 (1988) http://www.oldschooldaw.com/forums/index.php?topic=2867.0 DS/DD
S-550 (1988) http://www.oldschooldaw.com/forums/index.php?topic=2162.0 DS/DD
W-30 (1989) http://www.oldschooldaw.com/forums/index.php?topic=2016.0 DS/DD
S-770 (1990) http://www.oldschooldaw.com/forums/index.php?topic=3179.0 DD/HD *1.44
S-750 (1991) http://www.oldschooldaw.com/forums/index.php?topic=2480.0 DD/HD *1.44
DJ-70 (1992) http://www.oldschooldaw.com/forums/index.php?topic=2111.0 DD/HD *1.44
S-760 (1994) http://www.oldschooldaw.com/forums/index.php?topic=1363.0 DD/HD *1.44
illustrated
S-550 (1986) http://www.oldschooldaw.com/forums/index.php?topic=2162.0
roland color monitors:
http://www.usedprice.com/items/computer/roland-digital-group/crt-monitor/cc121-color-266773.html
http://www.rolandus.com/blog/2014/02/19/roland-synth-chronicle-1973-through-2013/
Roland S-XXX Sampler Tool (running on windows XP)
« Reply #2 on: February 23, 2023, 12:54:50 AM »
What is S-xxx?
Directx 9.0c or later
1.5  GHz processor
1GB RAM
50 MB free disk space
1 S-xxx hardware interface
3 Button or Wheel mouse
How does it work?
RC100-USB-Interface hardware
Re: roland s- series samplers
« Reply #3 on: February 23, 2023, 01:01:16 AM »
video showing replacement of the floppy of a s330 roland sampler
replacing it with https://hxc2001.com/download/floppy_drive_emulator/
HxC Floppy Emulator
Offline smoot smooth.as.silk
« Reply #4 on: July 03, 2025, 10:25:36 AM »
You can find a lot of software and sound files of the original Roland samplers on this site https://www.sgroup.ca (sgroup.ca - Roland Sampler Users Group)
Editor for the Roland S-10 MKS-100 and S-220 https://www.sgroup.ca/archive/utilities/s10/s10manager/
I myself still have a Roland S-220 & S-330. The 220 with a virtual USB drive. Also an LCD screen connected to the S-330 with mouse. Roland made beautiful industrial designs in the years 1988/94 in my opinion. A lot of old stuff still works. Sometimes the capacitors need to be replaced or the power supply. Otherwise very stable. Hardware nowadays seems to be of much lower quality.
« Reply #5 on: July 09, 2025, 03:46:10 AM »
Does anyone here still use the old 12-bit S-series samplers from Roland? Like the S-10, S-50, MKS-100, S-220, S-330, and W-30, before the 16-bit machines? I love the raw sound and workflow.
Offline protrusion
« Reply #6 on: November 16, 2025, 10:29:45 PM »
Yes yes.  I find it a useful tip (?) that Alchemy can do sample dump over MIDI to S-330 ... but as we know, W-30 cannot do sample dump over MIDI.  So, having an S-330 can be useful if you are also a W-30 user.  Use Alchemy with the S-330, then save to floppy, and load the floppy in the W-30, etc.
