Author Topic: Passport Alchemy 3.0 (1996 article) supports early samplers from 1984-1992  (Read 21602 times)
http://www.soundonsound.com/sos/1996_articles/jun96/passportalchemy.html
http://web.archive.org/web/20160303190540/http://www.soundonsound.com/sos/1996_articles/jun96/passportalchemy.html/
http://www.theemus.com/documentation/other/Passport_Alchemy_3.0_Manual.pdf
specific support for the following samplers:
Ensoniq EPS,
Ensoniq Mirage,
Ensoniq EPS/SCSI,
E-mu Emax,
E-mu SP1200,
E-mu EIII,
Akai S900,
Akai S1000/S1100,
Casio FZ-1/FZ-10,
Roland S-550,
Roland S-50,
Seq Prophet 2000/2002,
Yamaha TX16W,
Oberheim DPX-1,
and lastly, the Ensoniq ASR-10 was added
Alchemy 3.0 supports version 3.0 of the Apple Sound Manager.  That means that PowerMacs, AV Quadras,
and add-on hardware that supports Sound Manager 3.0 can play back 16-bit audio directly.
.WAV File Support
Alchemy 3.0 has the ability to read and write 8- and 16-bit .WAV files.  Files translated with Apple
File Exchange, PC Exchange, or similar programs can be opened in Alchemy if they have the type
“WAVE” or a .WAV file extension.  8-bit files are converted to 16-bit when they are opened.  The
Save As dialog allows you to save files in either 8- or 16-bit .WAV format
Alchemy sample-editing software for the Macintosh has been around for some years now, but after disappearing briefly (as if to gauge its popularity) it's had a facelift and staged a comeback. At least part of the reason for this new lease of life is Digidesign's decision to remove sampler support from its Sound Designer II software. Sound Designer II started out as a sample editor, and allowed you to transfer audio to and from a range of popular samplers, but has now been optimised for editing complete audio recordings rather than short audio samples. This has opened up a niche for Alchemy 3.0, which has been upgraded to support the most popular samplers currently available. I'll run through the new features first, before recapping on the basic package, and offering a few tips and hints on how to get the best from it.
NEW FEATURES
Existing Alchemy users will be pleased to hear about the many useful new features: the Soundfile Info dialogue has been expanded to include a pop-up menu which lets you access all open files, a new Graphical Key remapping function, and loop start/stop information. The Graphic Keymapping provides a quick and easy way to assign pitch ranges to samples using the mouse, while the Loop Information allows you to numerically adjust loop start and end points, or turn loops on or off.
The Process menu also has some additions. For instance, the Pitchshift Dialogue now shows frequency in Hertz and cents, to allow finer adjustments than previously, and the Resample dialogue now features an option to set sample rate conversion based on the period of the sample (ie. how often the waveform repeats itself). If you click the button labelled 'Sample Period', the sample rate is recalculated to an integer multiple of the sample period, which makes looping much easier. Once you've set your loops, you can change the sample rate to suit the particular sampler you are working with -- and that includes any changes you've made.
Talking of looping, Alchemy 3.0 now lets you adjust loop points in the waveform window using the left/right arrow keys on your Macintosh keyboard. Using the modifier keys (Command, Shift and Option) you can edit either the left or right loop points, or move both loop points together. These great features allow you to loop your samples much more quickly, accurately and efficiently before transferring them to your favourite sampler, with the benefit of seeing much more on your Macintosh screen than in any sampler currently available -- including the Roland models, which let you attach a video screen for editing.
Several new commands appear in the Edit menu for selecting harmonics in the Harmonic Spectrum window (the window which appears when you analyse a soundfile). Using these commands, you can select particular harmonic ranges of a sample to cut or shift up or down -- and you can achieve some very useful effects using these features. So, for instance, to create short echo effects, you can select every fourth harmonic and cut these, then select every third harmonic and replace these with the previously-cut fourth harmonics. This will shift portions of the harmonic spectrum down by an increasing factor, and the shift in the higher frequencies will result in that portion of the sound content playing back more slowly -- resulting in the simulated echo effect. Another helpful command is 'Select Less Than', which can be used for selecting all the lower-amplitude harmonics and then clearing them. This will sometimes clean up a sample, resulting in greater clarity.
"You can build up a library of useful envelopes -- stored as waveforms with the appropriate envelopes -- for future sound-designing projects."
Alchemy 3.0 can now open mono and stereo Sound Designer II, SoundEdit and stereo AIFF files -- which means that you can open just about any type of audio file you are likely to come across on your Mac. Alchemy 3.0 can also read and write 8- and 16-bit WAV files, which are commonly used on PC systems. Files translated with Apple File Exchange, PC Exchange, or similar programs can be opened in Alchemy 3.0 if they have the filetype 'WAVE' or the .WAV file extension, and 8-bit files are converted to 16-bit when they are opened. The Save As dialogue then allows you to save files in either 8- or 16-bit WAV format. You can set the file type of any file on your Macintosh (using Apple's ResEdit and other popular utilities) so that they will be recognised by the appropriate software.
Support has been added for the Digidesign Pro Tools I and Pro Tools III boards, along with the older Sound Accelerator II and AudioMedia II boards. Alchemy 3.0 also supports the RasterOps MediaTime board favoured by some multimedia producers, and using the Apple Sound Chip available in most Macs, you can now play stereo samples without using any third-party boards. And Alchemy 3.0 now supports version 3.0 of the Apple Sound Manager, which means that PowerMacs, AV Quadras, and add-on hardware that supports Sound Manager 3.0 can play back 16-bit audio directly. The Listen button in the Open Special dialogue will also play loops in looped samples. Finally, support has also been added for Opcode's OMS and for MTP-compatible multi-port MIDI interfaces.
Sound files can now be recorded directly into Alchemy 3.0 using the Apple Sound Manager v3.0, so there is a new 'Record Sound' item in Alchemy 3.0's Action menu. Sounds are recorded into free RAM (the amount of free memory available to Alchemy 3.0 is always displayed in the Tool Palette). Don't worry if you run out of RAM for recording; Alchemy 3.0 will stop the recording process for you, although you might get a little frustrated unless you have mega amounts available!
When you choose 'Record Sound', a dialogue will appear where you can make the appropriate settings. Here, you can choose between the input device (which could be the Mac's built-in digitiser, or a Digidesign or RasterOps board), set the sample rate and resolution, choose mono or stereo, and monitor through -- if required. With everything set, you use the Record, Stop and Play controls until you're satisfied with the result, and then hit Done. The newly recorded sound file will appear in an untitled window in Alchemy 3.0, and to save this you just use the standard Save As dialogue and select a file format. A good tip here is to make a test recording and then check this in Alchemy 3.0's waveform window, to see if the loudest portions are clipping, or if the levels are too low, before making your final recording.
MAIN FEATURES
Once you have some sound files to play with, you can use the Waveform Drawing mode to redraw a waveform, which can help to eliminate pops or other glitches. This is a useful tool at times, although in practice, it can be very difficult to correct such flaws.
If you are preparing material for your sampler, you will probably want to loop the sound next. The looping tools are pretty comprehensive, and there is an excellent section in the manual which describes how to make simple splices, crossfade loops and mirror loops, with plenty of tips on achieving perfect-sounding loop points. There are also various simple tools available to let you reverse a sound, invert the waveform, fade in or out, sample rate-convert and so forth. You can also apply digital EQ to any waveform, choosing from low shelf, high shelf and peak/notch type EQ filters, and set parameters for centre frequency, cut or boost, and width in the case of the peak/notch type. The EQ features are not quite as comprehensive as those in Sound Designer II, which also offers graphic EQ (and dynamics processing), but they are adequate for basic EQ'ing tasks.
The most basic edits you might make will involve Cut, Copy and Paste operations, and you can choose to use the Blending functions here if you like. Blending is an auto-crossfade function which is carried out every time you use the Cut, Paste or Insert commands. When you perform one of these edits with the Blend function on, all edit splice points are automatically crossfaded with each other to produce a smooth splice transition. The size and slope of the automatic crossfade range used at each splice point is set using the Edit Options command in the Edit Menu. Using the Blend function ensures that your edits will not cause a click, pop, or 'brick wall' transition at splice points.
The Blend function actually accomplishes its task by overlapping the waveforms before and after an edit splice point, according to the size of the Blend Amount. Since wave data is being overlapped, the overall duration of the sound will be generally decreased -- so you do need to keep this in mind when using this function. There is now a handy button just above the numeric display at the bottom of the Tools palette, which lets you turn Alchemy 3.0's Blending feature on and off, rather than using the Edit menu item. There is also a numerical display to the right of this, which shows the current blend time in seconds; a mouse click on this time field will open the Edit Options dialogue, where you can change the Blend time amount.
TEMPORAL DISPLACEMENT ZONE
In common with Sound Designer II, Alchemy 3.0 lets you do both time-stretching and pitch-shifting. Sound Designer II offers more control and can sometimes achieve better results while time stretching, but on the other hand, Alchemy 3.0 will detect the pitch of the sample for you -- while in Sound Designer, you have to compare the sample pitch with an A440 tone, and set the pitch manually.
Pitch-shifting allows you to change the pitch of a sampled sound accurately, with or without changing its duration. To shift the pitch, you select a range (or the entire sound) and choose Pitch Shift from the Process menu. You get a dialogue box, with a music keyboard, where a dark grey key indicates the selected sound's current pitch. Just click on any key to choose the new pitch, or type a transpose amount into the 'Transpose by' box. If you want the pitch-shifted sound's duration to match the original duration, you can select the Preserve Duration option. When you have made the settings you want, just click OK to execute the pitch-shift. Using this feature, you can quickly create harmonised sounds by first pitch-shifting your original sample (such as a guitar note) down by the interval you want, copying this to the clipboard, undoing the pitch-shift on the original sample, then using the Mix command in the Edit menu to mix the pitch-shifted sample with the original sample to create your desired harmony.
Time Scaling is the process of changing the duration of a sampled sound without altering its pitch. To apply this, select the range to be scaled, or select the entire soundfile, and choose Time Scale from the Process menu. Type in a new end time for the range, or type in a scale factor describing the relationship between the scaled file and the original file. Then hit Calculate. The Duration value is automatically updated to how long the processed file will be. When you are happy with this, click OK to apply the process. Scale factors between 0.7 and 1.3 are suggested for best results, as more extreme values will alter the sound too much. A 'Grain Size' field has been added to the Time Scale dialogue to help you get more flexible results. A Grain size with the default value of 30 has always been used for time scale operations in Alchemy 3.0, but prior to version 3.0, the Grain size was inaccessible to the end user. It is now possible to decrease the Grain size to as small a value as '2' or as great a value as the sample rate, size, and time scale factor will allow.
"Alchemy 3.0 is an indispensable tool for anyone involved in sampling who has a Mac."
The Grain size is an arbitrary unit used to define a 'time slice'. During a time-scale operation, time slices are analysed for frequency and amplitude content, and a new time duration is constructed, one slice at a time. Smaller Grain sizes can result in a 'smoother' end result, but there are trade-offs. To start with, smaller Grain sizes will require more time for computation. Also, when using smaller Grain sizes, the low-frequency content may not be properly analysed. The lower the frequency, the more samples are required to determine the frequency, so if you use too small a Grain size, the low-frequency content in your sample may be lost entirely. Using a larger Grain size produces sounds that might best be described as 'more chunky'. The end result can sound similar to an echo effect, as longer 'time slices' of the sample are reproduced. Another nice bonus is that time scale operations are faster with larger Grain sizes.
As with other DSP effects, the best way to understand and learn what does and doesn't work is to experiment. Rather than limiting the use of this feature (by limiting the range), the field will accept any value from 2 on up, and only warn you if the Grain size or time scale amount is unusable. The Grain size cannot be 'larger' than the duration selected, for instance. As to what a 'Grain' actually is, well, technically speaking it's a 111000th of the sample rate, plus a 'taper' factor. The taper amount ensures that the size result is an even multiple, and is also used to blend the time slices together. Again, don't try to analyse this one too much -- just fool around and see what works.
ADVANCED FEATURES
So far, the features we have looked at are similar to those available in Digidesign's Sound Designer II software, but Alchemy 3.0 goes quite a bit further, with specialised features for sound design.
As in Sound Designer II, Alchemy 3.0 offers a spectrum analysis feature. Sound Designer offers more display options than Alchemy 3.0 -- but Alchemy 3.0 lets you not only display, but also edit the harmonics, which is a much more powerful feature. Alchemy 3.0's harmonic spectrum display shows a series of vertical lines representing the individual harmonic components of the waveform you have selected to analyse. The height of each line represents its amplitude, while its horizontal position represents its frequency. Just select the part of the waveform you're interested in, and hit the 'Analyse' button in the Tools palette. This brings up the harmonic spectrum display, where you can select any harmonic using the mouse, get a readout of its frequency and amplitude in the numeric display at the bottom of the Tools palette, and drag it up or down to change its amplitude.
If you want to select all the harmonics above or below this, there are menu selections in the Edit menu. These commands mean that you can use the harmonic spectrum display effectively as a very accurate low-pass or high-pass filter, to remove all frequencies above or below a particular frequency. To hear your results, click on the waveform display, and then on the Resynthesize icon (the palette tool which looks like a sine wave). Another use of this feature is to take out (or reduce in amplitude) any unwanted harmonics -- a hum, or any other annoying frequency component, for example.
Unfortunately, there is a limit (32,768 samples) to the length of the audio waveform you can analyse, and you can only edit one channel at a time within a stereo file. These are serious limitations, which restrict the use of this feature to relatively short samples, and make it less convenient for working with stereo files. Of course, as with Sound Designer II, you could always use the spectrum display to look at the harmonic content of a small, hopefully representative, portion of your waveform, and thereby identify problems such as unwanted frequency components, or too much energy in any part of the frequency spectrum, and then apply EQ filters to correct the problem.
Another useful feature is the 'Replicate' tool, which lets you copy a range of your waveform and repeat this over a large waveform area. This tool functions by taking whatever waveform you have copied to the Mac's clipboard, and duplicating it repeatedly until it fills the new range you've specified. For instance, if you want to repeat a sound or a portion of a sound to get a stuttering effect, and your soundfile only contains the sound you want to repeat and nothing more, you will need to extend the Sample Size (that is, the length of the soundfile), to make space for the repeats you want.
If you want to do this precisely, you need to know the exact length of your original soundfile -- which you can find by selecting the whole file, and checking out the Soundfile Setup command in the File menu. This brings up a dialogue box, which shows the Sample Size as a number. You need to multiply this by the number of repeats you require, and then type the new number in the Sample Size box. Now when you look at your waveform, the display is much longer, but the new part is empty. To make your repeats, select the original waveform and copy it to the clipboard. Next, select the entire waveform, including the blank portion, before hitting the Replicate button in the Tools palette (the icon for this looks like two matchstick men standing side by side). Now you will have the exact number of repeats you want, exactly filling the length of your soundfile. This does seem a little 'fiddly' at first, and the instructions in the manual are a little vague at times, but once you've got the hang of it, this is a useful tool.
WELL SYNTHESIZED
The next pair of features, the Amplitude and Frequency Enveloping modes, take us well into the realms of sound synthesis, offering the opportunity to apply volume and pitch envelopes to your sounds.
The Amplitude Enveloping mode allows you to adjust or trace the amplitude envelope of any sampled sound. Traced envelopes can be copied and superimposed over other sampled sounds, so, for instance, you could trace the envelope of a violin, and superimpose that envelope over a piano to alter the way its volume changes over time.
"These great features allow you to loop your samples much more quickly, accurately and efficiently before transferring them to your favourite sampler."
This feature is pretty easy to use. With a soundfile open, when you click on the Amplitude Envelope mode icon, the waveform will be greyed out, and a horizontal amplitude envelope line will appear near the top of the Y-axis. This default position indicates that the amplitude is at its maximum value for the duration of the sample. If you click on this line, you will create 'break points' wherever you click, and you can set any number of these. You then drag these breakpoints around to set the particular amplitude levels you want over time within your soundfile. Once you are happy with the shape of the envelope you have drawn, choose the Amplitude Fit tool to increase or decrease the amplitude values in your soundfile to fit exactly under the new envelope. Alternatively, you can use the Amplitude Scale tool to adjust your waveform to the correct shape, although not necessarily to the same actual amplitudes (this option is provided because, in practice, Amplitude Scale works better on low amplitude sounds, or those that contain areas of silence).
Have you ever wanted to make a sample decay over time exactly as another sample does? For instance, imagine a sample of a guitar pluck which dies away fairly quickly, so that its amplitude envelope is like a sloping line starting high and falling off to zero quite quickly. You decide that you like the way this sample decays, but you want to use a different guitar sound. The other guitar sound you want decays in a different way, so you need to force its decay envelope to match that of your original sample. Easy -- just open the sample file with the desired envelope, switch to Amplitude Envelope mode by choosing the ADSR-like icon from the Tools palette, and then choose Trace Envelope from the Process menu. This draws an outline of the decaying envelope of your plucked sound. Copy this to the clipboard using the Copy Envelope command in the Edit menu. Next, open the guitar note sample you want to use, switch to Amplitude Envelope mode, and choose Paste Envelope from the Edit menu. The amplitude envelope you originally traced and copied from the sample you liked is now pasted into the new guitar sample's amplitude window.
At this point, it is recommended that you use the Scale feature to scale the amplitude envelope to the maximum amplitude value, to make sure that the resulting waveform will make use of the full amplitude scale. Finally, click on the Amplitude Fit icon. This fits the plucked envelope which you want over the more sustained envelope of your new sample.
When I tried this the first time, I got a little confused -- until I realised that I was applying the envelope from a three-second file to a six-second guitar note. The general shape of the envelope was still the same, but the six-second soundfile still took six seconds to decay, while I had somehow expected it to just last three seconds -- like the envelope. To make this work properly, I had to edit the six-second guitar note to last just three seconds, so that the new note sounded just like the original fast-decaying plucked guitar note.
BACK OF AN ENVELOPE MODS
In a similar way to that described above, Alchemy 3.0's Frequency Enveloping mode makes it possible to modulate the frequency of any sampled sound by drawing in a modulation envelope, or by pasting in any waveform to act as a modulation envelope. When you click on the Frequency Enveloping mode icon (which looks like a sawtooth wave) in the Tools palette, your waveform greys out and a horizontal amplitude envelope line running along the X axis is shown, indicating that no modulation is being applied. You can click on this line to insert break points, or just use the default break points at the start and end of the sound, if you just want to make the pitch rise or fall from one value to another throughout the sound. You can select a frequency range of one semitone, one octave, or two octaves to define how far the pitch will be modulated when you drag the break points to their maximum plus or minus values in the display.
With everything set, choose Frequency Mod from the Process menu to apply the processing to the sound. The pitch of your waveform will then be modulated or shifted, according to the modulation curve defined by the modulation envelope which you have drawn. So, using the Frequency Enveloping mode, you can apply the envelope of one waveform to control the frequency (pitch) of another waveform over time. An example here would be applying heavy pitch modulation to a guitar sound, by using a sinusoidal envelope to change the pitch of the guitar sample over time.
First, open the Loop Sine sample on the disk of example files which comes with Alchemy 3.0, and copy this to the clipboard. Next, open the guitar sample you want to process, and select the Frequency Enveloping mode by clicking on the icon in the Tools palette. You can choose a frequency range setting in the process menu, such as '1 Octave', and then use the Paste Envelope command in the Edit menu to paste the sine wave into the Frequency Modulation window. You could use any waveform you like here, but the sine wave makes the process clearer to understand when you hear it. To activate the pitch-shifting, hit the Pitch Shift icon on the Tools palette. Now you will hear the guitar note being frequency-modulated up and down, one octave above and below normal pitch, according to the Loop Sine envelope.
In practice, you can copy any envelope or waveform to the clipboard, and then use this as the amplitude or frequency envelope for a different file. There is no actual difference between an envelope or a waveform when it is in the clipboard, so if you think you have a useful envelope which you may want to use again, simply copy it to the clipboard, and save it into a new file. You can build up a library of useful envelopes -- stored as waveforms with the appropriate envelopes -- for future sound designing projects.
SUMMARY
All in all, Alchemy 3.0 is an indispensable tool for anyone involved in sampling who has a Macintosh computer. Yes, you will almost certainly want to have Sound Designer II and a Digidesign board to work with, and you may well want a selection of other tools such as Steinberg's Time Bandit for time-stretching and pitch-shifting, or the various plug-ins for the Digidesign software which offer a wide range of signal processing functions. Nevertheless, when you are preparing sounds for use with a sampler, Alchemy 3.0 has the extra features you will need to get the best results.
TAPPING OUT A TUNE
Alchemy has a great Multi-Tap Digital delay feature. The Echo item in the Process Menu brings up the Multi-Tap Digital delay dialogue, which you can use to add simple or more complex echo effects. The upper portion of this dialogue displays one of five identical panels, one for each of the five delay 'taps'. Using the Tap pop-up menu, you can select each panel in turn, and make appropriate settings. The enabled taps have a black diamond next to them in the pop-up.
To enable additional taps up to a maximum of five, choose an unused tap from the pop-up and, when its panel appears, check the enabled checkbox. Each tap can have its own delay time, initial delay, decay time, level and pan position, although the Pan position is only available when you're processing a stereo soundfile, and both channels are selected. The initial delay is used to set the time between the first occurrence of a sound and the first reflection (or first repeat) of the sound. The delay time is the time between subsequent repeats. The decay time determines how long the delayed signal will repeat after the first reflection occurs. 'Delay time' ranges from 1 to 3000 milliseconds, with 'Initial delay' from 1 to 3000 milliseconds, and 'Decay time' from 0.0 to 30.0 seconds.
The relative amplitudes of the dry and wet signals can be adjusted in two ways: the Level control sets the level of the processed signal for each tap, while the Mix control sets the overall mix of dry and wet signals. If you check the 'Echo within selection only' checkbox, this will force the effect to be constrained to the selected region. Otherwise, the effect will extend beyond the selected range, or if the entire soundfile is selected, lengthen the sample.
Alchemy comes with a few preset delay settings already provided, but you can also save an unlimited number of your own. The presets include Stereo Bounce, Stereo Spread Simple Echo, Slapback, Reverbish, Pan Bounce and Roomverb. To choose a preset, click and hold on the pop-up menu in the lower part of the dialogue and choose from the list. To create a new preset, make your delay settings and click the New button. A dialogue appears that enables you to name your preset and add it to the pop-up list. The Store button allows you to save changes to an edited preset, while the Delete button removes the current preset from the pop-up menu. Altogether, this is a pretty serious feature, which offers the sound designer the opportunity to experiment directly on-screen with various types of sophisticated multiple delay effects.
USING ALCHEMY WITH THE AKAI S1100 SAMPLER
You can transfer sounds to and from the Akai S1100 (or S1000) via SCSI or via MIDI. SCSI is much faster, so you should use this in preference wherever possible.
First, select S1000/S1100 from the Network Menu, then choose Instrument: Edit from the Network Menu, to bring up a dialogue box where you can select the correct SCSI ID for your Akai sampler. Mine is set to ID 6, for instance. You need to check that your sampler is set to the same SCSI ID, of course, and you do this by hitting the MIDI button on the bottom row of buttons on your Akai sampler. Then hit the F7 button on the sampler to bring up the SCSI page. Here, you will see 'S1100 SCSI ID : ?' with the number your sampler is currently set to in place of the question mark I have used. To get a sound from or send a sound to the sampler, just use the appropriate commands from the Network Menu. You can also get or send all the sounds or a range of sounds if you prefer.
If you have samples already in your S1100, you may want to transfer these to the Mac to take advantage of the more sophisticated processing available in Alchemy, or any other Mac software you have, or maybe even just to do your looping in the much larger waveform edit window on the Mac's screen. Alternatively, you may already have samples on your Mac, or you may prefer to record them using Pro Tools to get the very best possible results, before transferring to the sampler. Once you have sent your samples across, you will need to set up a program in the S1100, with suitable keygroups from which to play the samples.
This is all very straightforward in practice, although I wish it was possible to set up the S1100 programs using Alchemy and then send these back to the sampler with all the samples. Obviously it would be good to do this with all the samplers supported by Alchemy, and this would involve plenty of programming effort. Nevertheless, it should be possible to add these features in a modular way -- perhaps using some kind of software extensions to offer this feature for particular samplers.
Re: Passport Alchemy 3.0 (1996 article) supports early samplers from 1984-1992
« Reply #1 on: November 19, 2016, 04:32:14 PM »
Alchemy supports the following hardware:
AKAI --
S900,  http://www.oldschooldaw.com/forums/index.php?topic=1479.0
S950, http://www.oldschooldaw.com/forums/index.php?topic=3154.0
S1000, http://www.oldschooldaw.com/forums/index.php?topic=1553.0
S1100, http://www.oldschooldaw.com/forums/index.php?topic=2862.0
S3000,
S5000 http://www.oldschooldaw.com/forums/index.php?topic=3938.0
S6000 http://www.oldschooldaw.com/forums/index.php?topic=4264.0
( MIDI & SCSI )
CASIO --
FZ-1,
FZ-10M,
FZ-20M
DigiDesign --
Sound Accelerators,
AudioMedia,
AudioMedia II  http://www.oldschooldaw.com/forums/index.php/topic,1580
Macintosh sound expansion hardware
E-mu Systems --
Emulator I
Emulator II,
Emax,
Emax II,
SP-1200,
EIII (MIDI, RS-422),
E64,
E4x,
Ultra Series,
Esi 32/4000
ENSONIQ --
Mirage,
EPS /
EPS 16+,
ASR-10 /
ASR-88 (MIDI and SCSI)
KORG --
Triton,
T1,
T2,
T3 (SDS)
KURZWEIL --
K2xxx Series (SMDI)
PEAVEY --
SP,
SX (SMDI)
Roland --
S-50,
S-330,
W-30,
S-550,
S-7xx Series (SDS)
ALSO SUPPORTED:
Any other unlisted Sampler compatible with:
SMDI http://www.oldschooldaw.com/forums/index.php/topic,5000
or SDS(Sample Dump Standard)
(check ur device manual)
s950 http://www.oldschooldaw.com/forums/index.php?topic=3154
w30 http://www.oldschooldaw.com/forums/index.php?topic=2016
akai s3000 http://www.oldschooldaw.com/forums/index.php?topic=1399
asr-10 http://www.oldschooldaw.com/forums/index.php?topic=861
korg t2 http://www.oldschooldaw.com/forums/index.php?topic=3399
mirage http://www.oldschooldaw.com/forums/index.php?topic=2164
sp1200 http://www.oldschooldaw.com/forums/index.php?topic=2010
eps16+ http://www.oldschooldaw.com/forums/index.php?topic=2131.0
similar support to that of TURTLE BEACH SAMPLEVISION FOR WINDOWS
http://www.oldschooldaw.com/forums/index.php?topic=606
« Last Edit: February 09, 2018, 07:39:17 PM by chrisNova777 »
http://www.muzines.co.uk/articles/alchemy/3956
Sampling keyboards have come a long way in the last three years, and as a result, the visual editing software available has rather fallen behind the specifications and features of current machines. Until now that is, with the advent of Alchemy from Blank Software, boasting a whole bunch of features new to computer-based sample editors. Paul Wiffen investigates.
Figure 1.
The next generation of samplers is already with us and in the coming months the number of machines available with stereo sampling, 16-bit quality and megawords of sample memory will increase alarmingly.
Already the Emulator III, Prophet 3000, and Ensoniq EPS show how far those manufacturers have come since their last generation of samplers, and Akai and Dynacord will soon be joining the exalted ranks with their state-of-the-art machines. The last year has also seen the arrival of 16-bit stereo sampling on computers, with Dyaxis on the Mac and ADAP and Lynex on the Atari ST.
Until recently, however, things had been a bit static in the field of computer-based visual editing of samples. Digidesign, who were the first into the field, have faithfully adapted their Sound Designer package (originally created for the Emulator II) to work with the numerous 12-bit machines which have appeared in the last couple of years, while Steinberg have made a similar range of software available for the ST in the form of their Soundworks editors. But none of them can handle a true 16-bit sample (because none of the compatible samplers can) and none of them are designed to deal with stereo signals.
Enter Alchemy, a 16-bit stereo sample editor from Blank Software of San Francisco. The program runs on the Apple Macintosh family of computers and there is one universal version for all the supported samplers. Of course, this is not a completely novel concept; the most recent version of Digidesign's Universal Sound Designer can communicate with many different samplers (although not those for which there exists a specific version, unfortunately). What is unique about Alchemy is that all the samplers it supports can be kept connected to the Mac all the time via their various interfaces and then switched between in software. Blank call this the Distributed Audio Network or 'DAN' for short.
Once you have connected a sampler to the Mac via MIDI, RS422 or SCSI (depending on which communication method the sampler in question uses), then you can add each sampler by name to the pull-down menu called 'Network' and simply select it for sample transmission. In case you use several MIDI samplers, Alchemy can also control a MIDI patch bay automatically for you, so that even MIDI switching is taken care of when you select a sampler on the Network menu.
Whilst this facility is great for people like me who have access to several different samplers, it may seem a bit gratuitous if your budget stops at one sampler. But hold on - remember when your friend bought that Emax instead of the S900 you have and you were disappointed that you couldn't swap samples? Well now you can trade samples without any compatibility problems!
Now seems as good a time as any to go through the samplers which are supported by Alchemy. Blank Software began life with visual editing packages for the Mirage and SP12 drum machine, so it is no great surprise to find Ensoniq and Emu products taking the majority placing in the supported products list. Both the Mirage and the brand new EPS are catered for, along with the Emax, SP1200 drum machine, and the recently added Emulator III. Seeing as Akai's S900 has probably now become the most popular studio sampler. Blank have wisely included it in their fold. And, as Alchemy runs on the Macintosh, it makes sense to include the IMS Dyaxis - a stereo sampling recorder which uses a Mac as the control interface and stores the sounds in Mac format on hard disk. This is currently the only way of getting 16-bit stereo samples (which make Alchemy the highest spec editing software) into the network, although the EIII will shortly expand this. Talking to Donny Blank, they fully intend adding the Akai S1000 and other 16-bit stereo samplers, as and when they are released.
Of course, each of these machines has a different bit resolution, different sample rates etc, so not only will Alchemy have to undertake any necessary data format conversions but the final sound quality and usability with the Mac depends heavily on the features of your sampler. With this in mind, let's now look at the features and restrictions involved in using each of the supported samplers.
Although the Ensoniq EPS uses the slowest interface to Alchemy, MIDI, it is nonetheless the fastest sampler to use. This is due mainly to two specific features. Firstly, the EPS can accept just the sections of a waveform which have been altered in Alchemy. This means that if you only made small alterations to a sound, you can hear these very quickly because only the altered data needs to be sent instead of the entire sample. This avoids perhaps the biggest problem with most sample editors. Secondly, many of Alchemy's functions are duplicated on the EPS (crossfades, scaling, reversing, etc) so instead of changing the data in the Mac, Alchemy remotely controls the same operation within the EPS using MIDI System Exclusives, thereby completely removing the need for data communication before an altered sound can be heard on the EPS sampler. Stereo samples which cannot be made on the EPS can, however, be played back when transferred from Alchemy, and the assignment of left and right signals to different layers and the appropriate panning is taken care of automatically by Alchemy.
Emu Systems' Emax is another excellent sampler for communicating with Alchemy because it can use the RS422 interface which runs 17 times faster than MIDI. You do have the extra expense of purchasing an RS422 connecting cable (which will set you back about £25) but believe me, it is well worth the outlay as it not only increases the speed but also the reliability of the data transfer. Alchemy automatically sets up the necessary assignment and panning when a sample is sent from another source.
Although the Akai S900 can only communicate at the slowest rate due to using MIDI for complete sample transfer each time, it is well worth waiting for the result. Automatic assignment and panning of stereo sounds is again featured.
Neither the SP1200 nor the Mirage can handle stereo sounds, but you shouldn't let this put you off. The sound quality obtained by sending samples from other sources into these devices is far superior to their own sampling capabilities, and in the case of the Mirage this difference is so great it is probably worth the cost of the system on its own. Add to this the extensive editing capabilities of Alchemy and you'll find your Mirage moving up a league in sound quality and flexibility. The SP1200 also benefits from the availability of facilities normally found only on a keyboard sampler.
Although these are the only 'supported' samplers in the current Alchemy version (more will be added as they become available), there is apparently a limited form of communication available with other samplers via the MIDI Sample Dump Standard. This means that it should be possible to send and receive samples from the Prophet 2000, Oberheim DPX1, Dynacord ADD-One, Yamaha TX16W and Akai MPC60 at this level (which does support loops as well as sample data). Unfortunately, I didn't have a MIDI Sample Dump compatible machine available during the review period, so I was unable to test this. In fact, nowhere in the otherwise extremely comprehensive manual does it mention MIDI Sample Dump, and I couldn't find any options or parameters in the software which featured it, so we will just have to take this feature on trust. However, I would like to see the MIDI Dump Standard available on Alchemy's 'Network' menu as a selectable option (together with a transmission channel number, which some samplers - the Akai MPC60 and the Lynex for example - are now implementing, even though I believe it is not actually allowed for in the MIDI spec). This would make for a really powerful network, with 95% of samplers being covered either through specifically written systems (those already 'supported' plus those that are added in future updates) or through the general MIDI standard. It would certainly increase the number of potential sources for sounds.
Apart from this mysteriously 'hidden' MIDI Sample Dump facility (which only needs bringing into the open), I can find very little fault with Alchemy at all as a communications interface between samplers. Its flexibility stems from the facility to convert the existing sampling rate of a sample to any other rate. As you probably know, every sampler employs a different set of sample rates (33kHz, 44.1 KHz etc), so to keep the original pitch the same when moving from sampler to sampler you need to be able to convert the sample rate. Alchemy does this brilliantly, increasing sound quality when a higher rate is chosen, yet retaining the fidelity to a surprising level when the rate is lowered (certainly much better than making a sample at the same lower rate). This means you can exchange sounds between samplers without running into tuning offset problems (which used to dog me in the past when transferring Sound Designer files between different samplers!).
As a network controller, then, Alchemy is superb. But how does it fair as a sample editor?
The first thing you need to do is call up the sound samples you want to edit. That's right; with Alchemy you can edit several sounds at once on-screen, either in the conventional 'layered windows' manner that all Mac users will know, or much more usefully with a 'tiled' layout that divides the available screen space amongst the number of files you have opened (see Figure 1) - with up to six samples visible simultaneously. I found this much better to work with than the standard layered windows approach as you can see all the sounds at the same time, ideal for cutting and pasting. Of course, if you need to see one sound in great detail you can quickly zoom in and expand the display to fill the whole screen, popping it back into its allocated tile when you have finished your detailed work.
Figure 2.
The major advantage Alchemy has over previous sample editors is its ability to deal with stereo sound files, and there is a special display for this (Figure 2). Note also the overview section (available in both mono and stereo) so that no matter how finely you zoom in on the waveform, you still know where you are within the sample. An icon allows you to open and close this overview.
Icons also control many of the editing functions. All the fade and crossfade functions are similarly accessed, which saves all that tedious pulling down of menus. Cut-and-paste editing is more flexible than most, with Insert and Extract commands in addition to the usual edit commands. 'Extract' allows you to pull a section out of a sample and discard the data in front and behind (like truncating start and end points in one fell swoop). 'Insert' allows you to slip in extra data without overwriting anything already in the target sample.
If you don't have a stereo sampler, the Alchemy manual guides you through the process of sampling first the left and then the right channel, transferring them both into the Macintosh, creating a stereo file from the two mono sides and ensuring they are 'in-sync' (a real pain if you don't use Alchemy), then downloading them into your sampler with stereo automatically assigned. This is just one of the many such talk-throughs which are dealt with in the manual under 'Guided Tours' or 'Applications'. In fact, this is one of the best features of the excellent manual, which doesn't just give you a rundown of the facilities available but takes you through standard and advanced applications, helping you extract the maximum benefit from your investment...
'Loop Window' is by no means a novel feature these days - but that doesn't mean you can live without it. Blank Software's previous program, Sound Lab, was the first I saw that let you move the front and back of a loop independently, so naturally they have included this facility in Alchemy. When standard looping fails you, there's always crossfade looping to help out with smoothing away glitches.
