Author Topic: Novation Remote SL 61 (2005?) 10.3.9+ XP+  (Read 11897 times)
« on: October 27, 2016, 12:29:50 AM »
most likely compatible with current os choices from 2006+ such as Tiger, Leopard, Vista, Windows 7, Snow Leopard
also compatible with OSX Panther v10.3.9!
https://d19ulaff0trnck.cloudfront.net/sites/default/files/novation/downloads/4183/english90.pdf
http://web.archive.org/web/20070624065456/http://www.novationmusic.com/productlist.asp
http://web.archive.org/web/20090220010906/http://novationmusic.com/products/midi_control/remote_sl/
http://www.musicradar.com/reviews/tech/novation-remote-sl-61-22254
https://us.novationmusic.com/answerbase/do-i-need-to-install-drivers-to-use-the-remote-sl
http://web.archive.org/web/20060211002846/http://www.novationmusic.com/product.asp?id=30&Type=1&bArchive=False
specs:
http://web.archive.org/web/20070629001156/http://www.novationmusic.com/product.asp?id=30&view=specs&Type=1&bArchive=False
downloads:
http://web.archive.org/web/20070617225151/http://www.novationmusic.com/product.asp?id=30&view=downloads&Type=1&bArchive=False
Open up certain applications with the SL connected and all instruments (and mixers etc. in some applications) within the session will be detected and mapped to logical areas of the SL, with their controls displayed clearly on the screens. All the user needs to do is press one button or click once with the mouse to switch between controlling different instruments. Currently supported applications are Reason 3 and Cubase SL/SX3. Click here to find out more.
he ReMOTE SL is a class-compliant MIDI device so it does not require its own drivers. It can use the MIDI drivers built in to Mac OSX (10.2.4 or higher) and Windows XP, XP X64, Vista and Vista X64.
Pre-installed onboard Templates and Automaps
Software:
Novation
• V-Station
• Bass Station
Propellerhead (only Automap)
• Reason – All Instruments, Mixer, rack effects
Native Instruments
• FM7
• Pro 53
• Battery II
• Kontakt II
• B4
G Media
• Oddity
• ImpOSCar
• Minimonsta
Steinberg
• Cubase/Nuendo Automap - Mixer/Effects and VSTs
• Halion
Cakewalk
• Z3ta
Korg
• Legacy Cell
• MS-20
• Polysix
reFX
• Vanguard
Arturia
• CS-80V
• Arp 2600V
Rob Papen/Linplug
• Albino
Apple
• Logic Automap - Mixer and Instruments
Ableton
• Live Automap - Mixer/Navigation and Effects
Re: Novation Remote SL 61 (2005?) 10.3.9+ XP+
« Reply #2 on: November 03, 2023, 07:50:01 PM »
trying to get this to work in macOS mojave 10.14 if anyone has any info to help please post!
« Reply #3 on: November 11, 2023, 03:23:12 PM »
3.1 usb driver available here
https://downloads.novationmusic.com/novation/remote/remote-61-sl
im having some issues with this.. it works sometimes -- then it doesnt?
maybe im doing something wrong? maybe i need a firmware updatE?
« Last Edit: November 16, 2023, 09:35:12 AM by chrisNova777 »
« Reply #4 on: April 20, 2024, 11:58:08 AM »
my problem with the remote sL was solved using a different USB cable...
https://www.sweetwater.com/store/detail/ReMOTEPS--novation-psu6-power-supply
apparently the remote sl uses a 12v 1250A power supply (center positive)
If wanting to control hardware MIDI devices (e.g. sound modules) with the ReMOTE SL then an external power supply (Novation PSU-6, not supplied) will need connecting first or batteries will need inserting. To insert batteries, turn the SL over, remove the battery cover and install 4 C-size batteries. Once done, the ReMOTE SL can be
connected using standard MIDI cables (not supplied) to and from the hardware device.
